Swap Time
Old Jul 3, 2011 | 11:45 AM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Swap Time
Ive be-boped around and now im getting closer time for the swap.
If nobodys familiar with my car, Its a 84 sports coupe, 2.8.
350 4 bolt main, bored .30 over,
4 valve relief flat top, speed pro pistons
Vortec Heads
HEI dizzy
(https://www.thirdgen.org/forums/memb...ject-84-a.html)
(https://www.thirdgen.org/forums/engi...ulling-v6.html)
I wasnt too decided on what i was going to do, but in light of recent events, such as blowing my 3800 twice, im going forward with this for my short time DD. so i can get back to work. lol
First off, Ive got to get the mounts swapped.
Are the v6 mounts heavy enough duty to suport the sbc? or should i get the new mounts for a v8?
http://www.oreillyauto.com/site/c/de...2327&ppt=C0019
( i entered 87 350 camaro for my parts)
Second, where in the heck does it bolt up to?
I dont see anywhere for it to mount....
so, im assuming i need the v8 mount. But, will my HEI clear the firewall?
Lastly: does anybody recomend fabing a "vortec intake" by drilling a standard intake out, or just buy a vortec intake?
Old Jul 3, 2011 | 11:56 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: Swap Time
I don't think v6 mounts even work on the v8, totally different sizes.
Old Jul 3, 2011 | 12:36 PM
Guest
Guest
Posts: n/a
Re: Swap Time
You can't get most non-Vortec intake manifolds to cover all of the Vortec intake ports. They're much taller. Summit has a Vortec intake for $130, so sell the one you were hoping to modify, and get that instead.
You can use the V6 mounts if you get some V8 S-10 swap brackets.
http://www.summitracing.com/parts/ADD-713111/
http://www.summitracing.com/parts/SUM-226018/
Old Jul 3, 2011 | 12:54 PM
Engine: 355 chev
Re: Swap Time
thanks fellas..
that stage 1 intake is the one i had picked out anyway. lol
I feel the same on the mounts..
Old Jul 5, 2011 | 11:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Swap Time
the v8 mounts are so cheap that its almost silly not to grab new ones. i think i paid about $20 for both of mine (rubber ones; poly inserts added another $45 to the tab) at my local part store, no need to grab any adapters. Also, the v8 mounts use the front 3 most holes, but you should be able to get a better idea with one in hand.
Old Jul 7, 2011 | 09:39 AM
Engine: 355 chev
Re: Swap Time
Yeah, after looking at the picture of them, I realized how it mounted. Ill pick up the new ones, they're like 7.99 a piece, so ill go ahead and get those. Then its the big decision of vortec, or 882's... a standard SBC intake for 50... or vortec intake for 150? And pray I can get ahold of a valve spring, a set of locks and a retainer. Then get the assembly stuff.
Ive got to conjure up something to get the rust out of my lifter holes. A little bit of surface rust has built up.
If I go vortec route,
Can I use a standard set of pushrods? And will a standard exhaust manifold bolt up to em?
Old Jul 7, 2011 | 12:43 PM
rffy's Avatar
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
Re: Swap Time
If you do decide to go vortec heads, make sure to get a new pair if you can. I was reading in hot rod mag that a good bit of the performance of the vortecs was related to the slick 3 angle valve job the general puts on these things from the factory and that most machine shops have a hard time duplicating that.
Just my 2 cents.
Old Jul 7, 2011 | 08:28 PM
Engine: 355 chev
Re: Swap Time
Just my 2 cents.
Good info. I wont be doing too much machining to them, just the vatting, and cleaning of crud. they've only got like 100k miles on them i believe.
Old Jul 7, 2011 | 08:45 PM
Engine: 355 chev
Re: Swap Time
after entering in my IVO/IVC EVO/EVC in desktop dyno and watching the hp drop, I started playing with advacing/retarding the cam...
(small engine build)
cam powerband at 2000-5,200
peaking at 338hp @5000 409ft-lb @ 3500 timing 0.0
Drop it back 2*
Peaking at 351 @5000 413@ 3500 Timing at -2.0
Drop it back 4*
Peaking at 362 @5000 418@ 3500. Timing at -4.0
Is it worth turning it back, or best to leave it at 0?
With vortec's i cant put more than .470-.480 lift in,
and summit and jegs cams are basically the same.
Intake Exhaust
Advertised Duration 282° 282°
Duration @ .050" 224° 224°
Valve Lift w/ 1.5 Rocker Arms 0.465 0.465
Valve Lift @ Cam 0.310 0.310
Max Lift Angle 109° 119°
Lobe Separation 114°
Cam Timing @ .050" - Opens 3° ATDC 51° BBDC
Cam Timing @ .050" - Closes 41° ABDC -7° BTDC
So .465/.465 282/282 is the biggest cam they make i can go to.
Not sure what the 882's will let me do, but i feel sure the ports on those will limit my hp wayy more than this little cam in the vortecs.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
86Base
Aug 8, 2015 01:34 PM
