350 swap
Car: 1986 pontiac firebird
Engine: 355 HSR
Transmission: 700r4 Automatic unfortunately
350 swap
Ok so i have an 86 friebird with a 305 tpi system. I bought a 350 TBI out of a 91 GMC Sierra. Im gonna put my 305 fuel injection system onto the 350 engine. I need to know wat all i need to do in order to put this 350 engine into my car. Any help would be greatly appreciated. Thank you
Re: 350 swap
The 305 might have the old style intake pattern, the 91 should have the newer style. Look at the 4 center bolt angles. Old style has them coming out at a 90* angle to the mounting surface, newer ones is like 70*(?) angle, more vertical.
You should probably start w/ some new injectors, for a 350.
Make sure you get a flywheel w/ that 91 motor, oil pan too.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 swap
you will need to reprogram the memcal to a 350, $6e mask is the best, 22 #hr injectors from southbayinjectors and keep that 91's flexplate. you can elongate the holes in the intake manifold or get one from a 87-92 tpi. and hope you have a heated garage, its cold in aurora today !!!
Engine: 355 HSR
Re: 350 swap
We wont be starting until friday, me and some buddies will be doing it together so hopefully we can get it done in a couple days. And yes it is heated thankfully. And i knew about the injectors but wats this memcal thing?
COTM Editor
Re: 350 swap
Jason I thought you car was a 87!!!! That CL add where you bought is said 87. Yep flexplate will be needed.
Guys whats the difference in the knock sensor? Later blocks use different sensor?
Engine: 355 HSR
Re: 350 swap
I thought it was too. However the title says its an 86, and the vin matches that statement so yea. Its ok. its a third gen thats all that matters lol. Later on down the line i might get a 92 firebird lol
COTM Editor
Transmission: 4L80E/4L80E
The larger injectors are only needed at max demand, and at altitude with a TBI engine, 22's won't be necessary, and the 19's will probably run better, anyway.
'86 is 1-piece rear main seal, like the '91, and the '91 may actually be a 168-tooth and wouldn't work with the '86 starter (not particularly an issue if you have stock exhaust) - just use the starter and flexplate that work together.
