Can someone help me figure out where this 350 came from.
Old Feb 23, 2012 | 05:02 AM
Fritomaster's Avatar
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
The only numbers I found on the casting was "10054727"
Old Feb 23, 2012 | 06:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Can someone help me figure out where this 350 came from.
Did you try GOOGLE?
Casting # 10054727
350, 86 and up, 2 or 4 bolt main, one piece rear main seal, some made in Canada.
Obviously a casting used for multiple applications; 4 bolts most commonly used in trucks
Only thing that would narrow it down further is the 3 letter code off front block pad
Old Feb 23, 2012 | 02:33 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Originally Posted by vetteoz
Did you try GOOGLE?
Casting # 10054727
Sorry I forgot to add that I did google it but wasn't sure if I could get more info.
Ah I was gonna ask how to narrow it down more but thanks I'll see if I can find it.
Old Feb 23, 2012 | 05:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No need for Google when it's available right here: https://www.thirdgen.org/forums/engi...g-numbers.html
The casting # won't be able to tell you any more than that.
Old Feb 23, 2012 | 07:31 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
OK I found Cj7187049
trying to find out what it is now
Old Feb 23, 2012 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That will be the last part of the VIN from the original vehicle. Look for a code that looks like V1207TRK
Old Feb 23, 2012 | 07:48 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
-doublepost *whoops*
Old Feb 23, 2012 | 07:49 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Where would this other code be located?
I found the Cj7187049 behind the alternator.
By the way thanks for helping
Old Feb 23, 2012 | 07:50 PM
five7kid's Avatar
Okay, stupid question - Why???
Everything you could possibly need to know about the engine can be determined by looking at it or measuring (like if it's be overbored or the crank has been ground - which knowing what it came from will NOT tell you).
If you're wondering about the cam, why? It should be a given that it will not be in the engine anymore when the engine goes into your car. You can tell by looking in the lifter valley whether it has roller lifters or can accept them.
Heads? Same answer. Look at the casting #. That will actually tell you more than the engine code.
Old Feb 23, 2012 | 07:59 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Well lol heres the thing I'm a noob to cars/camaros, I assumed I needed to know. But after reading your post Its pointless if I ever need the info I can just check it out.
I had just a stock rs before and never really had to do anything to it but I got t-boned before anything ever messed up and now the one I have the guy stuck a 350 in it and rigged up a bunch of stuff and I'm just starting to learn about everything.
Old Feb 23, 2012 | 10:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It should have been on that pad. It's possible the block was decked and some other number sequence is stamped there now. That doesn't look like an ending to current VIN numbers but the block casting says it should be a late model block.
Since very little will be original, what the block itself came from means very little. Once you get it decked to make sure the surface is perfectly straight, those numbers will be gone also.
Best guess from those numbers is that it's a 1987 block and from the casting number, it falls in the 86 and up range.
Old Feb 23, 2012 | 11:06 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Thanks for an online community everyone here is super helpful.... I think I found the only good part of the internet lol.
Old Feb 24, 2012 | 06:44 PM
five7kid's Avatar
I would guess that it was a replacement engine. Both the partial VIN and the engine s/n should have been stamped on that pad.
So, got a pic of the head casting #? How about a pic of the lifter valley? Those two will tell us a lot.
Old Feb 24, 2012 | 07:03 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
3rd Gen member sofakingdom has summed it up nicely
read
https://www.thirdgen.org/forums/post...90-post32.html
Old Feb 24, 2012 | 07:17 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Its snowing and raining and I haven't had time to check anything else.....
Thanks for all the help so far!
Old Mar 17, 2012 | 04:04 AM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
The heads are 14102193
Which after looking are from a truck.
Old Mar 17, 2012 | 08:40 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Truck 350 swirlport TBI heads, yep. Just a 64cc version of the L03 heads.
Old Mar 18, 2012 | 11:54 PM
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Ah... I'm curious what do you think the hp is with no mods beside edle intake and carb (Not saying it adds hp)
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
milk
Aug 10, 2015 06:26 PM
