horse power question engine swap
Old Mar 3, 2012 | 06:10 PM
txkenneth's Avatar
Car: 85 trans am
Axle/Gears: 3:73 posi
i have a 85 trans am, i pulled the tired 305 out . I do not see putting any money in the 305. I bought a used 350, appears to be clean. Picked it up out of a wrecking yard. Wondering what you could tell me about the engine and what to expect horse power wise. I plan to run headers, flowmasters, performer intake and a holley carb , probably a 3310 750 vac sec/ The numbers on the motor are
10243880 and the heads are 14102183 , i took the intake off , and it looks like it has roller lifters to me.
Old Mar 3, 2012 | 09:24 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
Re: horse power question engine swap
thats a ZZ4 crate motor hell of a motor to get outta a junk yard probly 400hp
Old Mar 3, 2012 | 09:40 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Damn dude. What'd you yank that out of?
Old Mar 3, 2012 | 11:35 PM
txkenneth's Avatar
Car: 85 trans am
I did not yank it out, it was sitting on the shelf, i paid 325 out the door for it, figured i could use it as a core if nothing else . Came with a 30 day guarantee. I've got it all cleaned up should be going in and starting in the next week or two.
Old Mar 3, 2012 | 11:50 PM
Car: 1992 Camaro RS
Well even if it's not a ZZ4 you still got a good deal. And If it is a ZZ4, you got a rediculous deal. 350hp turnkey motors go for $5,300. And thats the low horsepower ZZ4. I think they go all the way up to 425hp.
Old Mar 3, 2012 | 11:56 PM
txkenneth's Avatar
Car: 85 trans am
Any way to know what it is?
Old Mar 4, 2012 | 12:04 AM
Car: 1992 Camaro RS
Well, I couldn't tell you exactly what to look for, but here is some info on the ZZ4. Hope this helps. http://www.summitracing.com/parts/NAL-19201330/
Old Mar 4, 2012 | 08:21 PM
Tonygxp's Avatar
Car: '89 GTA Brilliant Red
great pickup.... take it apart and replace the crank/rod bearings at a minimum (if you weren't doing that already.. i would have it checked out at a local engine builder since you scored it so cheap, real buzzkill if you put it in and it blew up or was knocking/low compression.. you know? keep us updated please!
Old Mar 5, 2012 | 03:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That block was used from 95-2000 as well as for the ZZ4 motors. The head casting number is probably 14102193, not 14102183, which is for the swirl-port TBI head, which would probably make this a 1995 350 TBI motor.
Here's a reality check: Does your motor have aluminum or iron heads?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
