2.8 to a 350
Old Mar 4, 2012 | 05:23 PM
Albinobatmobile's Avatar
2.8 to a 350
The guy that gave me my bird has a 85 iroc with a 350 in it and e says it runs. But my 2.8 runs good and it may be a risk to do it. How much does it cost about to get this done at a shop
Old Mar 4, 2012 | 05:50 PM
ex-x-fire's Avatar
re: 2.8 to a 350
Alot, most shops do direct replacement type jobs, so the labor will be alot. Can you tackle a motor swap?
Old Mar 7, 2012 | 08:34 AM
re: 2.8 to a 350
I can't tackle a fuel filter
Old Mar 7, 2012 | 01:21 PM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
re: 2.8 to a 350
Sell your car and buy another one with a V8 in it already then.
No offense, but unless you're rich, this is not very plausible since you are not mechanically inclined.
BTW, going from a 2.8 to a 350 is a whole new world. There a lot of 'hidden' items with a V6 to V8 swap that makes it not really worth it unless you can do the labour yourself, like changing the suspension, K-member/V8 mounts, wiring, etc.
You're better off selling your 2.8 bird, cut your loses on it and buying a Formula or T/A already with a 350.
Old Mar 7, 2012 | 01:31 PM
drew2007's Avatar
Car: 86 firebird s/e
Engine: 2.8
re: 2.8 to a 350
couldnt he also just get the iroc and swap just the bodys? or will the firebird body not fit on the camaro frame?
Old Mar 7, 2012 | 02:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Frame"?
Old Mar 7, 2012 | 02:42 PM
drew2007's Avatar
Engine: 2.8
Re: 2.8 to a 350
chassie, frame, same thing depending on where your at
Old Mar 7, 2012 | 02:47 PM
five7kid's Avatar
As in, "Our cars are unibody with a front subframe"?
Old Mar 7, 2012 | 03:58 PM
Re: 2.8 to a 350
LMAO
Drew, the chassis on the Firebird and Camaro are identical. They share the same doors, same basic body lines, look fairly similar, however the sheet-metal for the rear quarters is different which inhibits you from swapping Firebird tail-lights and bumper onto a Camaro, and vice-versa.
You CAN however, take the front end off the Camaro, and swap the entire Firebid front end onto it (Fenders, Hood, Bumper, etc) and make yourself a Trans-Marobird...and vice versa you can do the same to the Firebird, make it look like a Camaro in the front.
You can swap all the interior panels over from one another too. Certain things wont work though, example you CANT use a dashpad from a firebird in a Camaro and vice-versa. But the seats, entire dash and center console, carpet, door cards, sail panels, etc, all of that is interchangeable.
The wiring harnesses are not exactly the same either as the bird has controls/gauges/switches in slightly different positions then the Camaro and the under hood harness is mostly the same but also slightly different to accommodate the pop-up lights, etc.
BTW, the chassis or "frame" of our cars, it's called an F-body and it's built utilizing a unibody construction process. The "frame" is literally welded/fused together with the floor/sheet metal of the shell.
Old Mar 7, 2012 | 04:17 PM
drew2007's Avatar
Engine: 2.8
Re: 2.8 to a 350
ya i know they are called f-bodies lol i was just trying to get the point across without being all technical
Old Mar 7, 2012 | 06:00 PM
five7kid's Avatar
The point is, there is no "body" to take off of the "frame". You could drop the front subframe from one car and swap it to the other, but that's as close to a "frame/body swap" as you'll get.
Old Mar 7, 2012 | 06:05 PM
drew2007's Avatar
Engine: 2.8
Re: 2.8 to a 350
ok
Old Mar 8, 2012 | 08:14 PM
Re: 2.8 to a 350
I'll just save up an get a new camero . How are those? What are te engine sizes ? I may buy a new camero and put the engine in my frebird. Would it ft
Old Apr 16, 2012 | 11:37 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
Re: 2.8 to a 350
same thing dude...the both came with the same engines....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
Formula_88AE
Sep 3, 2015 01:47 PM
