Engine swap help!!!!!
I was wondering if anyone has a v6 f-body and stayed with the v6 because i would like to keep it stock looking but with a little more power to amaze people with v8s. i have an 83 camaro with a 2.8 v6 and want to stay with the v6. any help would be great.
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: Engine swap help!!!!!
Dude I hate to be cruel but ARE.......YOU.......ON.......DRUGS?????
the only way to make a v6 hang or even mess with a v8, is power adders, as in blower,turbo, NOS.... on and on the list goes. if you want to stay v6 with more power, look into a 3.4l DOHC, or a supercharged 3.8l out of a Grand Prix, otherwise you are just throwing money away, I personally have blown about 8 of those 2.8's they do not like to be pushed hard, sory to bust up your party!!!
Seems like everybody's gotta learn "the hard way" "the first time"... Lord knows, I sure did. Sounds like this guy is about to bite off a big chunk of his own personal s*** sandwich.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
ther are many threads in the 6 forum on this, and the late, great Karl has a Tech Article on the 2.8 - 3.4 swap boogie. I used it as a guide in one of my swaps in the old 85.
No i am not on drugs. I was thinking about maybe swapping in a 4.3L out of and s-10 and maybe a stroker kit. i just want to be able to have the power and also the fuel efficiency.
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
A 4.3 would be nice. i currently have one in my truck. hauls pretty good (still waiting to put the 355 in it). you can put a cam in(if you can find a decent one) and turbo/nos.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Mainly it will cost you more and your belief that the V6 will get better mileage is false.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I'm a v6 believer (guy in the v6 section is running 11.1 sec 1/4 mile. that's decent!), but the '83 is not the best to start with. Crappy heads and crappy crank(?), if I remember right. Easiest engine swap in the world is a 3.4L. It can be done for $250, including the engine, but that'll only get you 160 hp. Then you'll need another force of motivation. My route is turbo. But even buying used & ebay, 300 hp will set you back about $1500.
If you just want power, sell your car and buy a v8 car. Easiest "swap" ever.
If you want lots of power & potential for cheap-ish, LSx.
If you want to be a little nuts and spend a little more, welcome to the club.
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
If i remember right the 4.3 is a hard swap. Read this thread below, depending on your wants you might consider a v6. Even though its proven that big powered v8's are easier
https://www.thirdgen.org/forums/v6/5...ocharging.html
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
This guy actually did the swap:
https://www.thirdgen.org/forums/engi...4-3l-swap.html
Not too much more work to make power with these than a V8. Ask Syclone/Typhoon guys. Or, you could check these:
http://www.hotrod.com/techarticles/e..._engine_build/
http://www.hotrod.com/techarticles/e...l/viewall.html
Just providing information already out there...
Car: 93 240SX
Engine: LQ9
Have you done any considerable research as to what it actually takes to put a complete setup together using one of the 4.3's and a turbo ?
Especially compared to something that you can buy off the shelf everything, to bolt in and go with a good V8 ?
Car: 93 240SX
Engine: LQ9
That 301 HP after installed in the car with the headers that wont fit (now you'd need custom)
will be more like 250 after installing all of the accessorys on it, they've got it there with NOTHING on the front and an electric water pump, compare that just to a bone stock LT1 that will do more like 320 HP on the dyno with everything, thats quite a difference, especially when you consider thats after a cam and head porting on the 4.3, and nothing on the LT1
Car: 93 240SX
Engine: LQ9
Caprice iron head LT1 (this is something I can run to the junkyard and pickup for $275 almost any day of the week)
http://www.carcraft.com/techarticles...d/viewall.html
We made a couple of dyno pulls to establish our baseline and were pleased with a respectable 282 hp at 5,300 rpm and 339 lb-ft at 3,800 rpm through the stock manifolds and cats.
Through stock manifolds (known to be a serious restriction on LT1's) and cats, it made 32 HP more than that 4.3 with its ported heads, cam, and electric water pump...
Engine: LSJ
Axle/Gears: 4.05
Ugh...I'm just putting out information. It's his car and his choice of what he does to it. The more information he gets, the more informed choice he can make on what he wants to do with his car.
Car: 93 240SX
Engine: LQ9
Things like where they put that vortech supercharger on the 4.3, people would often overlook the fact that they did so using 100 octane fuel, ended up popping a headgasket, as well as spent as much on the supercharger alone that an LT1 making equal power would cost...
Engine: LSJ
Axle/Gears: 4.05
University of Hard-Knock's: Knowledge through experience, success through perseverance. We all have to learn sometime that it's never as easy as others make it look.
All that information is in there. If he reads it, he'll find it.
Car: 93 240SX
Engine: LQ9
And no, not all the information he needs is there, nor in plain sight.
Engine: LSJ
Axle/Gears: 4.05
Swapping a V8 isn't exactly easy work, either. If he does a swap, he'll have a full project on his hands, whether he swaps to a different V6 or a V8.
Easier for you, maybe. Maybe not for him. An individual's values do not translate the same to everyone else.
Car: 93 240SX
Engine: LQ9
Whats not easier here with a v8 swap, the same things are going to be needed for a 4.3, as well as several things that you have to deal with aside from the common issues for both.
And yes, it really is easy, everything needed is available, if he can turn a wrench, with a little research and sense it can be done in a weekend with just a bit of planning.
An individuals "values" ? thats a joke right ?
All of the exhaust side of the 4.3 will have to be custom made, whether it be a turbo setup, or headers, if turbo like the sy/ty stuff you suggested you'll also add intercooler piping and fabrication in there.
The V8 is simply order the correct parts and bolt it together, theres no "individuals values" here.
Engine: LSJ
Axle/Gears: 4.05
OP, I wish you luck in your future endeavors, whatever those may be, more power to you. Unfortunately, it seems that your values, what you want with your car, don't matter here. Cheers.
Car: 93 240SX
Engine: LQ9
He's obviously got enough sense to ask for information, unfortunately you dont have enough experience to provide actual useful information, and just throw out bits of pieces from magazine articles, virtually none of which involve the specified engine installed into a thirdgen.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
My vote if you truly want to stay v6, get a 4.3 clean it up real good. All new bearings freeze plug ect. Put a pretty decent cam in it some dish pistons and complimenting heads. Headers if you can find them. If you want to go further, slap in a turbo/blower, a 150 shot and call it a day. Just remember, it’s your car do as you wish to it and don’t let anyone pull you away from your plan. If they do, just do what I do and kick them out of the garage.
Car: 93 240SX
Engine: LQ9
If you are going to bother doing a build on the engine you really should determined the power adder to be used before building, if its going to get gas then build it with something higher on compression, if it will get forced air then yes dished would be a good idea.
Car: 93 240SX
Engine: LQ9
Also if you are set on using a 6, another option to consider is the 3800, bellhousing flange is the same as V6 thirdgens, and you can get an L67 all day for a few hundred $, get a newer one and have a good starting point with 36#/hr injectors, as well as matching programming to start with. Good bottom end that will handle some power as well.
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
While we are tossing ideas around there must be hundreds of new Camaros totalled by now...the ultimate sixer swap would be the 323 hp 3.6L V6. Thats would be a cool 3rd gen. Power, 6 cylinders, mileage and a real Camaro powerplant!!!!
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
I would trade my lt1
Car: 93 240SX
Engine: LQ9
Where is the benefit that would make you want to trade ?
Car: 1989 SS
Car: 1991 Firebird
Maybe you know something I don't, but why would an all aluminum v6 weigh more than an iron block v8?
Why would a 60* v6 be wider & longer than a 90* v8?
Car: 92 RS Camaro
Engine: 4.3L V6
Transmission: Borg Warner T5
Axle/Gears: Borg Warner 9 Bolt
I daily drive a 4.3 3rd gen. I did the swap myself, the only thing I had to change was the computer... Aside from some exhaust work. I was driving an hour a day to work and back on less than 40 dollars a week if I stay out of it. Last weekend I took it to Miami from Seminole/Tampa area on a quarter tank. And the last time I got next to a vette on the highway I was with him until I had to shift to 5th. I have no complaints with my swap. But looking back, I would probably go with a 5.3 if I had to do it again.
Car: 93 240SX
Engine: LQ9
As far as wider, because its a DOHC engine again with huge cylinder heads, making it wide up top, just like virtually every other DOHC engine. I didnt say longer, though its probably similar in length.
My opinion is ditch the 2.8 altogether! The 2.8 is the worst motor GM ever built. If you truly want to stay with a V6 would be to convert to a 4.3 however a V8 swap 350 would get better fuel mileage that either the 2.8 or 4.3. I swapped from a 305 to a built 77 model 350 4 bolt main and getting 16 MPG pushing 450 HP.
Car: 1991 Firebird
Because the cylinder heads are huge, its got 3 extra camshafts, lots of people end up surprised by things like this because they never think of it, just hear its got 2 less cylinders and think it MUST be lighter.
And the LT5 easily packed 4 cams into the cramped C4 engine compartment.
And we are way off topic.
Engine: 5.7 / 7.4
the benifit would be that you could drive thru a puddle of water and not worry about the $300 opti-crap dieing.
dohc vc ohv, here's a f*rd rendition
Car: 93 240SX
Engine: LQ9
There are plenty of others who have actually owned them that have had the same experience.
ARE YOU NUTS LQ( in a 240sx???? hang on to your hat boys, it won't be stayin on your head otherwise. LOL
Car: 93 240SX
Engine: LQ9
Taken part in quite a few similar swaps, current one going on is an actual LS6, right hand drive converted 240sx, we've actually got the engine way further back than any off the shelf mount kit, as well as working on a set of 1-7/8->2.125->3" 4-2-1 headers
And stripping an LT1 4th gen this coming weekend to bolt it into a friends 240sx for some temporary fun until he gets the rest of whats needed for his 5.3, its an auto, but it'll do, we'll be strapping my bottle in and going to find out what it'll do.
But back to helping you, if you are still wanting to go with a V6 despite the many advantages of several available V8's, please let us know what you've got as far as fabrication skills, budget, timeframe, etc and it'll be easier to suggest a good route to follow.
I actually think that an Inline EFI 250ci say 70's and 80's vintage, running on a 4.3 ECU would be way trick. the 250 was capable of 25+mpg back in the day, with EFI ????who knows what it'll do????
theshackle
Mar 5, 2017 06:37 PM
