305 to 350.
Old Jan 10, 2013 | 12:59 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
305 to 350.
Someone i know has a 350 tbi from a pre 1994 truck for sale .. I need a new motor considering my number 2 cylinder is dead. Does anyone know if i can fit a tpi on it? Its center bolt valve covers.
Old Jan 10, 2013 | 01:05 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: 305 to 350.
Yes its the same setup but you need to check the center bolts on the intake for the motor in the truck and make sure they are angled like the ones on your tpi intake. Otherwise if not you would have to change the heads or customize something to work which i dont recommend.
Old Jan 10, 2013 | 01:40 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: 305 to 350.
sounds like a good reason to upgrade the heads!!
like he said it will all swap over, just checks those things. make sure to get the computer and everything too.
Old Jan 10, 2013 | 01:43 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 305 to 350.
First, what do you mean by Cylinder 2 is dead?
Pre 1994 as long as it is newer then 1987 will work. Look for centerbolt heads, like you have now. Otherwise the intake will not match.
Also, a truck motor is going to have a flat tappet cam, which will be smaller then a stock tpi cam and will not give as much power.
Of course, the truck engine is going to be pretty worn already, like what you have now. At the least you are going to want to check it over, and will probably need a re ring at a minimum.
Old Jan 10, 2013 | 01:54 PM
Axle/Gears: 3.47
Re: 305 to 350.
Compression. I would rather have an l98 but i have no choice because right now i aint got 500 for one.. I wanted to tear it down and get it bored n stroked to a 383.. So the cam would be upgraded. If im swapping a motor i wanna do it right.. Will these pullys from my 305 work on this motor? Swapping brakets ofcourse
Old Jan 10, 2013 | 01:55 PM
tzim350HO's Avatar
Engine: 350 carbed
Re: 305 to 350.
Yes
Old Jan 10, 2013 | 02:02 PM
Axle/Gears: 3.47
Re: 305 to 350.
Alright il try n post pics of that engine
Old Jan 10, 2013 | 02:09 PM
Car: 1971 Camaro
Engine: 427
Re: 305 to 350.
You ain't got 500 for an L98, but you're gonna build this one into a 383
If you are rebuilding, a core is a core. The Truck heads are not as good as L98 heads.
Yes, all the extranal stuff from the 305 will swap right over to the 350.
Old Jan 10, 2013 | 02:18 PM
Axle/Gears: 3.47
Re: 305 to 350.
This motor is 150. I never said it was going right into my car.
Old Jan 10, 2013 | 03:29 PM
Car: 1971 Camaro
Engine: 427
Re: 305 to 350.
Like I said then, a core is a core. No difference in the block from a camaro or truck.
Old Jan 10, 2013 | 04:18 PM
Re: 305 to 350.
yeah if you plan on working on the engine over time i would just save the money and work on the one you have.
Old Jan 11, 2013 | 03:13 AM
Axle/Gears: 3.47
Re: 305 to 350.
Turns out the block was a 5.0 .... No way am i taking that.
Old Jan 11, 2013 | 06:06 AM
Re: 305 to 350.
yeah not worth it
db057
Apr 28, 2019 07:45 AM
angel2794
Sep 8, 2015 06:22 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
