rpm air gap mainifold
Car: 88 Sport Coupe
Engine: 383
Re: rpm air gap mainifold
I have a performer air gap with a holley 670 and it fits fine under stock hood. Not sure if the RPM air gap is taller, but guys are running them on here.
Car: 88 Sport Coupe
Engine: 383
There's an air gap, and an rpm air gap. I know I run a performer rpm but also a 1" spacer. Even with a RAII hood it won't clear without a 2" dropped base air cleaner. With a stock hood and a performer rpm you would need a drop base and even then its going to be tight.
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
won't fix got one on my 383 and without the air cleaner the hood hits the top of the carb won't latch
Posted from Thirdgen.org App for Android
Car: 90 RS
Engine: 305 for now
Axle/Gears: stock 2:73
i have an edlebrock rpm performer air gap and it deff dont look like its gonna fit at all the carb is over the fenders with no air cleaner so i need a hood or gota get the saw out
how much of a cowl u guys think is needed to make it work
how much of a cowl u guys think is needed to make it work Thread
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
