L98 or L05?
Old Aug 9, 2015 | 09:53 PM
matthew911's Avatar
Car: 84 Z
L98 or L05?
Hey guys, novice here. My local junkyard has a couple L98's out of the 87-92 Camaros for $250, and some Caprice/Roadmaster L05's for $275. According to their system the L05 is a better fit for my 84 Z. I think the L98 has more HP and I'm not looking to go crazy on mods, just something fun to cruise around in. Any recommendations between those two? What mods would I need to make for the L98 to fit? I believe the guy at the junkyard mentioned the oil pan not fitting as well as moving the dipstick and a few other things.
We'll be switching it over to a carb. I've got an Edelbrock 1406 that was on my old 305. Do I need to pick up a computer and harness to match the engine or will the existing ones work?
Old Aug 10, 2015 | 12:27 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: L98 or L05?
The only interchange diff. on the L98 and L05 would be the induction system... If you are going to a carb then that will not matter.
The oil pan will fit fine and so will all other parts. I would pick the L98 myself.
If you are going with an edelbrock carb then you don't need ANY computer. You need the engine, the carb'ed intake, the carb and a large cap HEI mech. and vac advance dist.
You will also need the flexplate from the L98 as it's a 1pc rear main seal and your old 1984 305 is not.
Old Aug 10, 2015 | 09:55 AM
matthew911's Avatar
Car: 84 Z
Re: L98 or L05?
Excellent, thank you. Any particular recommendations on the distributor?
Old Aug 10, 2015 | 09:57 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: L98 or L05?
Any decent HEI with a vac advance. Summit house brand is fine.
Old Aug 10, 2015 | 06:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: L98 or L05?
I would stay with the L98 for the heads. But be aware that the "L98" may still have the 193 casting heads swapped on it.
Old Aug 10, 2015 | 06:23 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: L98 or L05?
^ good advice.
Old Aug 10, 2015 | 09:15 PM
Car: 1988 Camaro
Re: L98 or L05?
A lot of people hate the guy for selling imported/china performance parts but Skip White HEI dist. for $45 is hard to beat for the price.
Old Aug 11, 2015 | 09:35 AM
matthew911's Avatar
Car: 84 Z
Re: L98 or L05?
Thanks everyone, I'll take a look at all my options. One more question on the dist. Do I have to look for one that fits in that 87-95 year range? Would one that's listed up to 86 work for me or is that setup completely different? I've noticed those in the 87-95 range specifically mention they're not for LT1/LT4 so I assumed that's where I should be looking.
Old Aug 11, 2015 | 11:21 AM
If you're not using a computer get a vacuum advance large cap hei as Night said. Those will fit any sbc 1. If it lists years it will be 70s vintage. Started being used around 75 and my 86 gmc still had one. There were electronically controlled ones too, starting in 80-81. You do not want those.
Old Aug 11, 2015 | 05:33 PM
matthew911's Avatar
Car: 84 Z
Re: L98 or L05?
86 yes, but the engine will be out of an 87 or newer car. Amazon and other sites show a lot of them only working until 86. The ones listed for 87-95 are a bit pricier just like the manifold and some other parts. I think the L05 and L98 were kind of a bridge from the old SBC to the newer LT1 and then LS1, from what I've read. Just wasn't sure what all made them different from the older engines. Especially since I'll be going carb.
Old Aug 11, 2015 | 08:01 PM
Re: L98 or L05?
Let me rephrase this........THEY WILL FIT ALL GEN 1 SBCs....no ifs ands or buts. They'll even fit big block chevys. They 87 and later intakes are really only different by the inner bolts being at a different angle. L05 and L98 were just sbc's. Minor changes happened to sbc's over certain periods of time. Oil filters changed, dipsticks moved, rear main seals changed.....they still can use the same distributor.
I don't know which distributors you are looking at but if you are looking at both large cap, vacuum advance, HEI distributors, the only thing I can think that would be changing the price is gear material that meshes with the cam.
Old Aug 11, 2015 | 09:04 PM
matthew911's Avatar
Car: 84 Z
Re: L98 or L05?
Appreciate the reply, thank you. Want to make sure we get it right.
Old Aug 12, 2015 | 12:24 AM
Car: 1988 Camaro
Re: L98 or L05?
Here you go, $40 http://www.skipwhiteperformance.com/...px?Item=6500-R
You are doing a carb swap, you need the old style HEI that works w/o a computer or EFI.
That is the great thing about the gen 1 sbc engine.. You can swap parts back and forth on engines from 1955 to 2002.
The big diff in the '86 and up sbc engines was the swap from 2 pc. rear main seal to 1 pc. rear main seal.. 1955-85 was 2 pc., '86 up was 1 pc.. This changed the oil pan, flexplate/flywheel, crankshaft and of course the seal it's self.
Then in the '86 up engines they went to center bolt valve covers, and the 4 center intake bolt holes was changed to a more straight of an angle.
As far as the dist. goes you need an HEI mech/vac advance like the one I liked to.
Intake depends on what heads you use. If stock 1987 heads then you will need an aftermarket carb intake for the '86-95 engines
If you run most aftermarket heads or any 1955-85 heads you will need intake for that year range.
Old Aug 12, 2015 | 09:38 AM
matthew911's Avatar
Car: 84 Z
Re: L98 or L05?
Definitely can't beat that price. Appreciate the info.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
