Cant decide between zz6 or sp383 base crate
Car: 1992 z28
Engine: 305 tpi
Hi
I would appreciate any help on decideing what would be best choice between a zz6 base crate or a sp383 base crate to run with the satin first tpi intake?. Im also thinking the b&m tubo700 trans as it is advertised at 450 lb/ft. Im replaceing a tired 305 tpi in my 92 camaro and i have a budget of 20k australian dollars so i figure either of those engines with the rest into other parts needed maybe if i have change i can look at the interior.
Any feed back would be a great help as iv been unable to decide for a few months now.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Cant decide between zz6 or sp383 base crate
Sp383 has bigger cam and more cubes. I’d do that since bottom end is all the sams basically. Same type piston and rods and forged cranks
Both have fast burn heads
Car: 1992 z28
Engine: 305 tpi
Thanks for your reply. Do you think it would be possible to tune a prom from a 350 to run it or is the painless ez efi a petter option?
Car: 89 Iroc-z
Transmission: TH400
As a tpi tuner i would def recommend tuning the stock ecm. Cheaper and easier. But it is a bit of a learning curve
Car: 1992 z28
Engine: 305 tpi
Would you be able to do a base tune for me as i have no idea on tuning? And how much would it cost if you could.
Thanks i appreciate the help.
Car: 89 Iroc-z
Transmission: TH400
Sorry i dont do those unless the work is done at the shop i help tune for
Car: 1992 z28
Engine: 305 tpi
One thing I have learned, and have offered this advice to others as well: Figure out how you're gonna tune if BEFORE you spend a dime. If you're gonna have someone do it for you, call them and make SURE they'll tune whatever system you're running. I couldn't find anyone in my area who would tune my stock ECM.
Car: 1992 z28
Engine: 305 tpi
[QUOTE=Abubaca;6214969]One thing I have learned, and have offered this advice to others as well: Figure out how you're gonna tune if BEFORE you spend a dime. If you're gonna have someone do it for you, call them and make SURE they'll tune whatever system you're running. I couldn't find anyone in my area who would tune my stock ECM.[/QUOT
i have thought about that. it is very good advice and i dont think anyone around me can tune the stock system in my camaro. I have been looking into othe options like the painless ez efi or some sort of piggy back set up. Do you have any suggestions as to what works best
Car: 1983 G20 Chevy
Transmission: 4L60
I bet you could repin your ECM harness to run the Holden 808 ECM used in your 308s and most likely MANY shops could tune it. 7730 is not much different but I actual prefer the Holden code in the 808 ECMs. The speed density coding in the 808 will run in the US 165 MAF TPI ECMs and I have played with the custom code developed for it ALOT. I would be willing to bet anyone that has played with the 808 can tune a 7730 and vice versa.
1b rock
Wheels and Tires
Jun 5, 2011 05:40 PM
