How to make a little extra power?
Old Feb 19, 2019 | 11:16 AM
JonJon5.0's Avatar
Im kinda new to Building Engines at home by myself I have a L69 305 with very low miles and I want to piece it together to have fun if I do Headers a High performance Carb Edelbrock intake lightweight Pulleys and Valvetrain Upgrades what kind of Power Numbers will I Get...Money is not a Problem
PLEASE NO COMMENTS ABOUT GET A 350
Old Feb 19, 2019 | 02:51 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: How to make a little extra power?
You could get 250 with above mods and maybe a mild cam
Old Feb 19, 2019 | 03:45 PM
BigDogBob's Avatar
Car: 86 Trans Am
Engine: Carb'd LM7
Transmission: TH400
Axle/Gears: Stock 2.73
Google is your friend
Throwing money at a 305 isn't advised, but if you stick with bolt-ons they'll transfer over to the 350 you'll wind up with eventually.
Old Feb 19, 2019 | 04:03 PM
Drew's Avatar
The L69 is already pushing it for a 305. It's got decent pistons, head, cam, intake, carb, exhaust, all from the factory. You're not going to see the same gains that you'd see modding a 140hp LG4.
People don't say to get a 350 because of some prejudice against the 305, it's sound advice based on decades of experience.
Old Feb 23, 2019 | 01:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Not the numbers your probably looking for; you might be better off just leaving it as-is and enjoying what you have. Why molest a good original HO Thirdgen car to try get something that you're probably not going to get - simply because of what you are starting with. The HO is a fairly quick ride, not much to brag about these days,....... but still pretty fun to drive. The second you modify your low-mile HO it's worth less $$ and desirability,... and how much will headers and an intake get Ya' ??? 15--20HP ?? Just not worth it -----> IMO !
Since $$ isn't a problem for you---> just buy a car that already has the potential to build up to the HP you desire.
Old Feb 24, 2019 | 12:43 AM
NoEmissions84TA's Avatar
Search member Ja85z28 and read what he did to his.
Old Feb 24, 2019 | 06:49 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
It's tough to get a 305 to breathe enough to produce significant power; the cylinder heads are the limiting factor, and the small bore size doesn't allow larger valves. A cam, headers & exhaust, intake, carb, and ignition system might get you maybe 25-30 horsepower.
What is your issue with replacing the 305 with a 350? If it's $$$, the cost of the above mods to the 305 are close to being enough to cover a Good Wrench crate 350.
Old Mar 9, 2019 | 08:48 PM
JonJon5.0's Avatar
It’s Like this I don’t need no crazy amount of Horsepower 3rd gens are Fairly light so if I can make a realistic 280-300 RWHP then I will be Fine I’m using the car for Driving in Mountains and twisty Roads it’s not a Drag Car I know I can Swap another Engine I just want to play with the car it’s just for fun...and if the 305 can Handle that amount of Power or produce it easy then I will look into something else
Old Mar 9, 2019 | 09:30 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
If money is no problem, skip the 350 and go sbc 454
Old Mar 9, 2019 | 09:31 PM
JonJon5.0's Avatar
Not Interested in Big Blocks
Old Mar 9, 2019 | 09:43 PM
427seven's Avatar
I said S B C 454.... You said money was not a problem...., right?
Old Mar 10, 2019 | 12:07 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Modifying a 305 isn't very rewarding. If you want to keep the 305 then I might suggest doing the typical cheap and free mods and leave it at that.
A supercharger would make quite a bit of difference and be reversible back to stock anytime you want.
Old Mar 10, 2019 | 12:58 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I think you live in Chicago....? There isn't a mountain within a thousand miles
Old Mar 10, 2019 | 01:09 AM
JonJon5.0's Avatar
Road trips with the car is always possible
Old Mar 10, 2019 | 02:44 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
LS swap + turbo $20,000 500rwhp reliable car
Thats about the only option I see anymore for daily drivers
Old Mar 10, 2019 | 09:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Exhaust and rear axle gearing, best two mods for that machine. Much like the Monte Carlo SS back in the day.
Old Mar 11, 2019 | 07:30 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I done headers and cam to an LG4 once and it was still a bit slower than my LB9 car I got a few years later to my surprise. If you bother with a 305 you probably wont be happy performance wise. Not saying its not a good engine because they are peppy and run forever, but a 350 is so much better for the $ I would never spend much on a 305.
Old Mar 11, 2019 | 07:37 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Well, a thousand miles will take you to either ocean, Alaska, Mexico, etc. My geography is lousy but Has to be a mountain in there somewhere.
Couldn't resist.
Old Mar 11, 2019 | 08:39 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Good thing you weren't a pioneer settler heading west from Chicago because you would have run out of supplies and died somewhere in the grass plains of Montana less than halfway to the West coast.
Old Mar 17, 2019 | 03:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 305 in my 1980 Vette was still mild and trapped 110 mph in the low 12s on drag radials with a TH350C and 3.07 gear behind it.
It was a flat top piston, .040" over 305. Ported Vortec 305 heads (059 casting) with 1.94/1.60 valves. Crane 272H10 cam with 1.6 rockers. Edelbrock Victor Jr single plane intake manifold. 500 cfm Edelbrock carb. Long tube headers and a pypes 2.5" dual exhaust with magnaflow mufflers. 3,000 rpm lockup converter in the TH350C. It idled 750 rpm with the a/c on and still pulled down 25 mpg highway.
I also had what amounted to a roller cam L69 with bolt ons in my old G20 van. It was a .030" over Vortec 305 block, flat top 1.56 compression height pistons zero decked, F-car LT1 cam, and 53cc 14022601 heads. An Edelbrock Performer RPM intake, tweaked Q-Jet, recurved HEI, 1.6 roller rockers, Thorley Headers and 2.5" exhaust with a X-pipe before the high flow cats and magnaflow mufflers. With a 2,800 stall converter in a 700r4 and 3.73 gears. It ran a 14.8 @ 94 in the big van. It idled 550 in drive with the a/c on and would get better than 20 mpg running 75 mph.
Old Mar 17, 2019 | 03:57 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
How low are the miles?
Old Mar 17, 2019 | 04:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My brothers old 1980 C10 went into the 13s with the shortblock from the Van. Ported 059s with 1.94/1.60 valves(later those were on the Vette), GM 845 cam, GM dual plane carb intake off a 330 HP 350 HO, Q-Jet, recurved HEI, shorty headers from a 1998 Vortec truck, dual 2.5" exhaust. Using a 3,000 stalled TH350 and 3.08 gears.
Old Mar 17, 2019 | 05:10 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by ironwill
It's tough to get a 305 to breathe enough to produce significant power; the cylinder heads are the limiting factor, and the small bore size doesn't allow larger valves...
Stock Bore & Stroke
LB9 = 3.736 x 3.480
2JZ = 3.390 3.390
Stock Valve Sizes
LB9 = 1.85/1.50 (two valve)
2JZ = 1.32/1.14 (four valve)
Simply put, a 1.94" valve is all the valve a naturally aspirated 305 will ever need to make great power (for its' size). If your 305 is boosted like mine, then sure you can try to swing 2.00+ valves in there for more room up top, but it's not really needed. It's more about cylinder head flow and cam characteristics when it comes to a naturally aspirated 305, but again, you won't see as much as you would with a larger engine. Free mods are meaningless in my opinion, if you're not going to pull the heads and get a better cam, then don't even bother.
- Rob
Old Mar 18, 2019 | 03:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Add to that intake manifold, fresh valve springs and 1.6:1 roller rockers to get a little more lift out of the stock cam. Testing even an edelbrock performer manifold over the stock manifold on those cars back in the day showed a 20 hp increase and a measurable 2-3 tenths off the track times.
kkirch15
Exterior Parts Wanted
Jul 25, 2015 09:08 AM
SomethingWild
Dec 14, 2011 08:23 PM
antosh
Jun 3, 2008 04:22 PM
MeanMachine1986
May 11, 2006 12:16 AM
