6.0 T56 swap. engine wont spin when i turn the key.
Old Jul 13, 2019 | 07:11 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
1992 used to be a 305/5-speed. I am all most finished with the swap. I used 100% HOLLEY swap kit including exhaust, more than happy with fit and outcome.
I have the starter hooked up correctly and am thinking maybe its a safety switch?. I have the clutch press all the way down but starter will not turn over. New batt, and starter.
Am I missing something or overlooking something? THANKS
Old Jul 13, 2019 | 08:42 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: 6.0 T56 swap. engine wont spin when i turn the key.
Couple things I can think of that you could check.
1) Neutral Safety Switch (I think it's a button type switch above the clutch pedal but I'm not 100% sure) - If it is this, you can try jumping the wires to see if it'll crank.
2) Ignition Switch - This had went bad on my car. Here's a thread that might help: https://www.thirdgen.org/forums/elec...ank-issue.html
Old Jul 13, 2019 | 08:59 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
This should be a sticky but the mods won't do it.
https://www.thirdgen.org/forums/elec...pass-vats.html
Old Jul 13, 2019 | 09:03 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
I always forget about vats since my car didn't come with it.
Old Jul 14, 2019 | 12:58 AM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Thanks QwkTRip, I have a complete PSI conversion system on the car. No vats.
Old Jul 14, 2019 | 01:07 AM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Thanks I,ll try that and see if it works. Im really thinking its probably a switch or a switch im going to have to jump.
Old Jul 14, 2019 | 03:01 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How does it bypass VATS? The old PASSkey module controlled the starter relay.
Old Jul 14, 2019 | 08:57 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Ok, I see whats going on here. I thought VATS was in the ECM. So this must be my problem. Ill go back and read the link on how to disable it. Thanks again.
Old Jul 14, 2019 | 10:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Ya, starter wiring is part of chassis harness EXCEPT for the start relay which was put there to allow PASSkey to disable the starter motor for security reasons. You can eliminate the relay and nothing is lost, unless you want to use it to interrupt the starter with a new anti-theft device.
Old Jul 15, 2019 | 11:22 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It DID also disable the injectors, so you were 1/2 way there
Old Jul 16, 2019 | 03:56 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Are you talking on the 92 ECM?
Old Jul 16, 2019 | 04:36 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
If the VATS is not the problem, the best thing to do is work your way back and test what Jorlain mentioned. Hook a remote starter switch to the starter and see it if turns over. If it does, then move to the next point, the clutch safety switch, at the bottom of the clutch pedal when pushed in. Pull the plug off. Test if you get power to the plug when you turn the key. If yes, then jump power to the other side to see if the starter turns. If the starter does not turn, then there may be a break in the wire. If you get power to the plug, and a jumper powers the starter, then its a bad switch. You can test continuity of the switch with an ohm meter while pushing on the switch by hand. If there is no power when you turn the key, the problem is with the ignition which is more of a pain. Oh yeah, do all this work on you back contorted under the dash!
Old Jul 16, 2019 | 04:52 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Originally Posted by TJQIROC
I Oh yeah, do all this work on you back contorted under the dash!
LMMFAO!!!! Thats exactly whats happening. And thanks for more info. Everything was working perfect before the swap. Then again anything can happen.
Old Jul 18, 2019 | 01:12 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
PROBLEM SOLVED. Had a relay in between solenoid wire that should have not been there. Thanks everyone.
BOTTLEDZ28
May 20, 2005 12:39 PM
pasky
May 27, 2004 04:56 PM
Black Beauty
May 15, 2001 11:53 PM
F-Messenger
Mar 17, 2001 02:05 PM
bad camaro RS
Sep 29, 2000 12:04 AM
