1991 z28 swap c207 speartech harness gauge wiring. Help?
Old Sep 22, 2024 | 01:31 AM
1LELS7's Avatar
Basically I’m trying to connect tach, speedo, oil pressure, ignition, water temp though the c207. I’ve searched though the stickies and threads. Can anyone break this down for me. If I’m correct “D” is the gray wire for Speedo? Just trying to get my gauges to work properly. I’m using a speartech harness. They bypassed the vats and everything should have signal. They used the 98-02 411 computer. Am I even thinking correctly on this?
Old Sep 22, 2024 | 10:59 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 1991 z28 swap c207 speartech harness gauge wiring. Help?
You need to find yourself a shop service manual with wiring diagrams. It's just too hard figuring out stuff without that. I don't have all the answers for you because I don't have wiring diagrams for your car, but this might help some....
Most your gauges go through a large connector (C100) on the firewall next to the brake booster. I don't know if the gauge pinouts are the same for 91 Camaro, but here are pinouts for an 88 Firebird to maybe get you started:
Pin, Wire Color, Function
D6, WHT, Tachometer
E5, TAN, Oil Pressure
F5, DK GRN, Coolant Temp
The voltmeter gets power from fuse panel, you don't have to wire that.
And you don't have to mess with the fuel gauge unless you're doing some changes back in the fuel tank, https://www.thirdgen.org/forums/ltx-...e-4th-gen.html
Speedometer is the one gauge that goes through C207. Pinouts can vary by year and I don't know your pin and wire color.
Old Sep 22, 2024 | 12:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
This will help
Pinouts of C100 and C207 for various years by Pocket
https://www.thirdgen.org/forums/ltx-...formation.html
Additional information about C207 and C100 connector by vorteciroc
https://www.thirdgen.org/forums/elec...al-poster.html
https://www.thirdgen.org/forums/elec...in-repair.html
Old Sep 22, 2024 | 01:20 PM
1LELS7's Avatar
Thanks QwkTrip. I’ve been studying both C100 and C207. Of course I’ll need the red A4 power wire, purple for starter solenoid and a pink for ignition. Things definitely change from year to year. I think that’s why speartech stop doing plug and play. Or for whatever reason.
Old Sep 22, 2024 | 01:30 PM
1LELS7's Avatar
I’m waiting to hear back from Justin at speartech. He said the c207 plug is all you need for gauge wiring. I persisted it was the c100 but what do I know. Hopefully he can find something in the books over there.
Old Sep 22, 2024 | 01:34 PM
1LELS7's Avatar
Does anyone know the exact break down? don’t have the service manual. I can keep looking and asking until I get one.
Old Sep 22, 2024 | 02:07 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My memory is there is something special about 91/92 C207, something that goes through there instead of C100. But I don't remember off top of my head.
Old Sep 22, 2024 | 03:20 PM
1LELS7's Avatar
maybe it will come to you. Once I can verify c207 for gauges I’ll get this thing wired and fired up! Just want it done properly.
Old Sep 22, 2024 | 04:07 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...-diagrams.html
Give that one a try
Old Sep 22, 2024 | 04:16 PM
1LELS7's Avatar
Originally Posted by Pocket
Thanks pocket! I’ll start reading now. Hopefully I can read this properly!
Old Sep 22, 2024 | 04:45 PM
1LELS7's Avatar
So according to this print. You can only access the speedo from the c207? Is that correct? The rest have to come from the c100? If that’s the case I’ll have to loop back around back inside the car where my loose wires are. Correct me if I’m wrong
Old Sep 22, 2024 | 07:14 PM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
It is a long time since I did the swap on my 91 RS ,but I think both the tack and speedo went though 207.and meet the existing factory wires under the pass side dash.
Old Sep 22, 2024 | 07:23 PM
1LELS7's Avatar
Thanks kestell. How did you figure that out? Followed it all the way thought the car or from a print? Are you using 411 computer as well? Didn’t work like a charm?
Old Sep 23, 2024 | 05:52 AM
kestell123's Avatar
Engine: LS3
Transmission: 6l80
I did my LS/6l80 swap in 2012/13 and was the first to get Speartech to make a plug and play harness for a third gen . The only wires that were not plug and play were those two. I ran them through Dakota Digital adapter boxes to get the correct outputs for the gauges. I sent Speartech my Camaro harness and they modified it for the LS/6L80 including DOD and VVT. At the time there were no stand alone controllers for the 6L80 so I used the GM E38 ECM. I had the factory service manuals including the electrical book most of which I have since sold. I will look if I have any of the 1991 books yet.
Old Sep 23, 2024 | 09:26 AM
1LELS7's Avatar
Justin at speartech was under the assumption you can get to everything from the c207. That’s why I was so persistent to find out. But the looks of it I’ll have to use the c100 as well. He said a customer sent a harness back in for them to modify and he referenced it being close to the kick panel passenger side fender. That’s probably you kestel. Won’t have to worry about a Dakota digital for correct output since they do that in the 411 correct?
Old Sep 24, 2024 | 12:41 PM
Pocket's Avatar
Car: 91 Trans Am
Correct, for 90-92 V6 and TPI cars, pin D goes strait to the cluster. For 90-92 TBI cars, use pin K, but jump pins C&F on the buffer box
Old Sep 24, 2024 | 01:22 PM
1LELS7's Avatar
awesome! Guess the next thing to do would be connect my pcm speedo wire to pin D on the male side and plug it into the clear female side and my speedo should work.
Old Oct 2, 2024 | 05:06 PM
johnw999's Avatar
It may have been my harness back in 2017. My installer couldn't get the engine to start. I gave him a Speartech harness and an ECM I bought from another programmer. My E38 ECU started another car in his shop, but the other car's ECU wouldn't start my car. So, I overnighted the harness back to Speartech along with my ECU. Justin said the ECU tune parameters were way off, and he reprogrammed it. My installer suspected a fault in the harness. I'll never know, but the engine started after the combo was sent back. And my installer attached the ECU to the passenger kickpanel.
QwkTrip
Sep 23, 2025 11:15 PM
Psycho_91Camaro
Southern California Area
Aug 4, 2006 03:56 AM
