Factory Serpentine on 454
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
So Kwik Performance makes adapter plates that allow the use of the factory serpentine system from an 88 to fit on a 97 454. The problem i am having is the power steering pully just comes into contact with the steering gearbox so i am thinking a smaller pulley should fix my problem. Does any know of a pulley that will work by chance or has anyone else used this setup and had another solution?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Factory Serpentine on 454
Wonder the diameter of a underdrive system from March
Car: `86 SS / `87 SS
There are a lot of PNs tossed around on LS swap discussions. Look out for the two diff. pulley i.d.s to match your pump.
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Ran into this issue using bbc serp. My thought was to use the ps pulley off of a 3.1 v6 maro. Smaller in diameter but I cannot tell you if it will align correctly as that project has been abandoned a long time ago.
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
I had to use one of these on my LS swap, due to the accessory drive I was running; the V8 pulley was going to interfere with the routing of the belt.
I have never done a BBC swap on one of these cars, but I can attest that the smaller V6 pulley will run your power steering just fine. It's just going to turn the pump a little faster.
roughskinjrz
Sep 8, 2005 02:19 PM
