L98 to LT1
Old Feb 6, 2002 | 03:16 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
L98 to LT1
Have a 1988 IROC w/ a blown-up 5.7 can get a rebuilt long block for $850. Or I can get an LT1 (Spun Bearing) out of a 1993 Corvette, minus intake. Can I get the the stock 1988 TPI to bolt on to the 1993 LT1 block and Aluminum Heads? Please Help , I have a buddy that said I can't but I just want to make sure. Also what is the above listed LT1 worth.
Thanks, Garrett
1982 Z/28 355c.i. 412 horse, T-10, Affordable Speed!!
Old Feb 6, 2002 | 06:28 PM
Tas's Avatar
Tas
ya you can put the TPI intake on the LT1 but it will really choke it if the TPI is stock. You will need to put new holes in the TPI base as the intake bolt holes are different on the LT1. Used LT1 intakes use to go for $50. You can get a new LT4 intake for $200 if you want to upgrade from your TPI intake later.
Old Feb 6, 2002 | 09:05 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Umm, no you can't put the TPI intake on the LT1 block. The heads are reverse cooled meaning there are no water ports on the heads, so you'd have to seal up that TPI manifold pretty good. Just find and LT1 intake and fuel rails on CamaroZ28.com for about $200 complete, sometimes less $. And do a full swapover. If you're not into doing a lot of custom stuff, then just rebuild your L98 block.
Old Feb 6, 2002 | 10:55 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I have seen complete running lt1s for 1200 dollars at speedautomotive before. That included the complete engine,harness,computer and full accessories. Why mess with a spun bearing,unless its cheap or free.
Kory
Old Feb 6, 2002 | 11:00 PM
Tas's Avatar
Tas
Um yes you can. If no coolant flows through the LT1 intake then there is nothing to seal up on the L98 Intake. The coolant passage will be empty and the thermostat housing will be blocked off since there is no use for it.
Old Feb 6, 2002 | 11:12 PM
Car: 88 Iroc
Transmission: t 56
Why would you want to do that? The engine is designed to run upstairs, if you put a tpi on it you may get it to run, but it will run like crap and look worse.
Just my .02
Kory
Old Feb 7, 2002 | 03:00 PM
Tas's Avatar
Tas
It will run like a L98. The cams aren't too different.
Old Feb 8, 2002 | 12:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Tas, why in the heck would you want port MISMATCH, the requirement of drilling new bolt holes, and a more expensive water pump replacement? You can do anything but c'mon
Old Feb 8, 2002 | 12:21 PM
Tas's Avatar
Tas
The ports match up. That's how people are putting LT1 intakes on L98s now. http://www.lt1intake.com/
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
