350/330 Will it work
Old Mar 4, 2002 | 10:40 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Now I finally got my funds together and I am ready to turn this dream project into a reality. I decided to go with the 350/330 crate motor and top it off with the TPI / Vortec base plate. All of this will go into my 87 GTA. I have been reading older posts and there are quite a few guys that are biased to the Tpi/Vortec bp. Before I place my order I just want to know if this setup will work and if there are any others out there with the same setup,and how does it perform? Also I know I am not in the correct thread to ask this but where can I get a GOOD 700R4 or should I go with a new one? Any input will be appricated.
Old Mar 5, 2002 | 08:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Define "work".
Do you have emissions inspection/testing to worry about? That will determine how much "work" it takes to make it "work". Since the Vortec heads don't have the exhaust cross-over passage, you'll have to plumb exhaust up to the base to get the EGR valve to work, for instance. Chip burning will also most likely be required.
Otherwise, recent issue of Chevy High Performance magazine had an article on the setup. It runs, but doesn't make as much power as the carbed setup, and aftermarket runners (really needed to get any kind of power) had to be modifed to fit.
Old Mar 5, 2002 | 10:20 AM
da BEAST's Avatar
Emissions are not tested here. So are you recommending a carb set-up to get the true power? If so which carb you recommending? Also I was wanting to get a ram air hood and was wondering if I could have a functional ram air set up with a carb? What are your thoughts, opinions on the 350/330 and if you were doing this project for you, which route would you take ?
Old Mar 5, 2002 | 10:23 AM
da BEAST's Avatar
One other thing, this will be a daily driver and on occasions taken to the track for releasing built up road rage.
Old Mar 5, 2002 | 01:32 PM
five7kid's Avatar
I'll pass on any further opinions, because those who know me know my opinion of the Vortec heads. I don't want to open myself up to any further claims of bias.
Old Mar 5, 2002 | 07:33 PM
da BEAST's Avatar
OK then do not give an opinion. Just tell me if you were doing this project what would you do? I have been reading some of your post and I value your responses that you have posted. I am not trying to set you up to get blasted because of your opinions. Just simply asking "What would you do?"
Old Mar 6, 2002 | 08:10 AM
five7kid's Avatar
If the extra funds required to make TPI work were available, I'd stick with TPI. Especially for a daily driver.
Old Mar 6, 2002 | 08:34 AM
da BEAST's Avatar
Thats all I need to hear.I will go with this set-up. Thanks bro
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
