headers are glowing red!
Old Aug 1, 2002 | 09:59 PM
chevy power's Avatar
i just got the car run'n after doing: aluminum heads, cam, ported intake plenum and runners and hooker long tube headers.
we were breaking the cam in, in the driveway. so it was at bout 1,500-2,000 rpm. after 5 mins of this the headers were glowing bright red. it was a little more obvious because it was dark out, but still should they glow like that? the computer is stock and it doesn't run the way it should (air fuel mixture all messed up) could it just be run'n very hot becuase of a not normal mixture of air /fuel? we shut it down after bout 5-10 mins and decided to figure this out before breaking in the cam for 20 mins w/ it glowing like that.
any ideas?
Old Aug 1, 2002 | 10:12 PM
psycomaross's Avatar
did you check your thermostat. your engine could be runnin' lean and heating up if that's not it "me no know"
Old Aug 1, 2002 | 10:36 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
It might be normal. Headers are thin tubing and it gets pretty damn hot.
Back in the days of piston/propeller driven airliners, on night flights, you could see flame shooting a couple feet out the exhaust pipes, and the pipes and exhaust plumbing was glowing bright red.
Old Aug 1, 2002 | 10:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A stat shouldn't have anything to do with it.
Make sure you're not running lean. The timing is probably off since you worked on it.
Old Aug 1, 2002 | 10:59 PM
craiger's Avatar
What changes did you do to the car? I know a new cam but how much bigger? I put a ZZ3 cam in my vett and the headers were doing the same thing! I had to put my fuel psi from stock 43.5 to about 48 psi to give the car what it needed....more fuel! YOu had better do the same! I would bet my next pay check that your runnig lean..lean is mean and will destroy your engine if you do not get it fixed! Do not romp on it until you get this problem resolved! I would increase the fuel psi to 46 and take a look for red headers, then if its not glowing, pump it up to 48 jsut for safety! If it is still glowing, increase 2 psi unitl it stops!
Keep us informed on the outcome.
Old Aug 1, 2002 | 11:01 PM
Car: 99 Formula
Axle/Gears: 342
Well, if he did a cam swap, he took out the dist. so you're not going to have the timing right, just by dropping the dist in. So I would say that's your problem. Start the car up to break in the cam for a few mins, then let it idle long enough to set the timing, then continue with the break in.
Old Aug 1, 2002 | 11:23 PM
craiger's Avatar
I assumed the timming is correct? If not, make sure it is! Mark has a great point! With all of your mods, you need to make sure that both your timming is correct and that your getting enought fuel. First do the timming since incorect timming can easily be fixed! Then increase the fuel psi. With your mods, I'll bet your needing more fuel psi.
Old Aug 1, 2002 | 11:35 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
dont just double check your timing. triple, even quadruple times check it. 3 times wasnt enough for me after my cam swap and i had the same problem. the timing was off 180 and i thought it was dead on stupid me. but the was on my first engine rebuild and i taught myself so i guess its not that bad but check it a couple times
Old Aug 2, 2002 | 12:08 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had SAME problem ended up being valves were way to tight and timing was WAY off.
Old Aug 2, 2002 | 09:48 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
What else do you have for an exhaust? Could it be something that is clogging? You are putting more pressure and volume through the pipes. Just a thought.
Old Aug 2, 2002 | 09:59 PM
Car: 99 Formula
Axle/Gears: 342
That is very possible, but I still think it's a timing issue.
Old Aug 3, 2002 | 02:54 PM
88Bravo's Avatar
Probably is but I just wanted to add something to be looked at. Kind of as what could it be now type of thing.
Old Aug 3, 2002 | 07:07 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Your timing is retarded and you're still burning that Air/Fuel mixture as it is being exhausted into the headers. I've had this exact problem before.
Tim
Old Aug 6, 2002 | 06:47 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
just out of curiousity what would be a normal exhuast temp for you guys
I have that same problem on my car where I have glowing red headers if I run at WOT for any time at all
timing is spot on and I am getting enough fuel into the system
just a thing the rotories do
Old Aug 6, 2002 | 08:42 AM
Car: 99 Formula
Axle/Gears: 342
Headers get to be around 1200+*. Of course that is different than the temp of the exh gas, cause cast iron manifolds get hotter than headers due to the material.
Old Aug 6, 2002 | 11:28 AM
Dragula's Avatar
Timing...Timing...Timing...
Old Aug 6, 2002 | 11:31 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yeah I was looking at exhuast temp readins like if you had a EGT in your exhuast
Old Aug 7, 2002 | 10:27 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Timing
If your cam is much bigger, you may have to run a lot more ignition timing at idle. With my large solid roller cam, I have to run at least 30-35 degrees timing at idle, otherwise my headers glow bright red at just idle. Hot enough to melt plug wire boots and make every plastic piece underhood brittle. My air/fuel was always a tad on the rich side, so it wasn't a lean condition.
Old Aug 11, 2002 | 09:35 PM
James Montigny's Avatar
Glowing headers
A few years back we built a monster of a 3.4 engine from scratch. We also added new pacesetter headers. I broke it in on my way back from the shop in Ohio (Had to be at work in KC 10 hours later). The headers' outside black coating turned bright white, yet the engine was running at a normal temp. By the time I got home, they were black again *shrug* never quite figured that one out.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheExaminer
Sep 28, 2015 02:28 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
andy74
Sep 3, 2015 08:41 AM
