350 tpi exhaust
Old Sep 10, 2002 | 12:03 PM
IROCafros's Avatar
350 tpi exhaust
what would be a good exhaust system for a 89 Tpi 350.
i mainy want more hp because it only has 240 hp but it has a ton of torqe
thx
Old Sep 10, 2002 | 01:01 PM
Brett Gutshall's Avatar
Do a search. This is asked hourly.
Old Sep 10, 2002 | 02:31 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: 350 tpi exhaust
thx
Hey dude, I have a 1991 Z28 5.7 TPI (L98) with 245 HP and 345 pounds of torque. I'm running FLowmaster 80 series.....they are supposed to give you a bit more horsepower......there isn't to much restriction with the 80 series. They sound MUCH louder on 5.7's then 5.0's.....nothing against 5.0's....there great engines as well. But...yeah...do some research if you want....but I love the flowmaster. Good Luck
Old Sep 10, 2002 | 02:45 PM
What makes them sound any better on a 5.7? 5.0s with dual cats have the same cam, manifolds, cats, catback so what is the difference? And if you're only looking for power Flowmaster is not the best choice. They don't flow nearly as well as the hooker and dynomax systems.
Old Sep 10, 2002 | 03:53 PM
Engine: 5.7
Well.....unless my 1991 Z 5.7 TPI (L98) has a different cam in it or something.....I know a bunch of guys that have the 305 TPI dual cat set up....and they don't sound near as deep or near as loud as a 5.7.......the only thing that is really different is the bore.....I have a couple of friends with the 5.7 TPI and they all sound much deeper and much louder then the 305 TPI's (dual cat)....and again.....nothing against the 305's....there great engines.
Old Sep 10, 2002 | 04:15 PM
jayhah2's Avatar
Ok, dynomax isnt really that great of an exhaust system, #2 a 350 is bigger than the 305 so its going to put out more of an exhaust tone than a 305.
Old Sep 10, 2002 | 04:45 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Oh crap, here we go again. Another 305 vs 350 war.
I'm gonna keep my mouth shut. Later!
Eric
Old Sep 10, 2002 | 04:50 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
correct me if im wrong... but wouldnt a set of aftermarket headers do much more than a catback exhaust? for a moderately larger investment id say youll see real power gains over a catback setup.
Old Sep 10, 2002 | 06:41 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
If i had a choice between the 2, id pick headers. They wake those cars up. But since its the most expensive bolt-on, its gonna have to be second choice for me.
But if talk about power gains, headers should give u more power than cat-back i believe.
Old Sep 10, 2002 | 11:03 PM
MdFormula350's Avatar
on my 88 iroc-z 5.7 i had a dynomax muffler and on my 88 formula 350 i had a flowmaster muffler.
both cars had about the same amount of miles and ran about the same times in the 1/4 mile, but the formula was definitely alittle louder than the iroc at really any rpm..
Old Sep 11, 2002 | 12:07 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What makes it sound different/better?? 45 more ci. of course. And Flowmaster flows plenty good, definetly enough for any stock or near stock 305 or 350 or more even. Amazing how people buy what manufacturers say. When I start seeing fast cars at the track and shows use something other than Flowmaster, maybe I'll listen.
Old Sep 11, 2002 | 07:36 AM
Yeah I see what you guys are sayin. Bigger engine, better sound, makes sense. And yeah IrocTwentyGR8, there are a lot of really fast cars with flowmasters, too bad mine isn't one of them.
Old Sep 11, 2002 | 10:19 AM
IROCafros's Avatar
what should i get if im gutting my cat?
Old Sep 11, 2002 | 01:03 PM
DakotaSLT's Avatar
In terms of power or sound? Power, a couple horsepower, nothing crazy but every bit helps . Sound, a little louder and more rumbly, I think the cat dampens some of that out, but not a 100% sure. Do you have to pass smog, cause that's the only thing stopping me from hollowing mine out and running a pipe through it.
Old Sep 11, 2002 | 03:54 PM
IROCafros's Avatar
so if i were to get an exhaust system should i not get a cat with it.. if i want to gut the cat i have right now?
Old Sep 13, 2002 | 10:30 AM
IROCafros's Avatar
im thinking about just putting a pipe in the place of the cat... right now i have all my exhaust off and it sooooo loud:rockon:
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
