Removing A.I.R. equipment
Old Sep 17, 2002 | 12:25 PM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
Since I am in the process of rebuilding the motor in my 88 IROC I was wondering how much of a difference it would make in my emissions if I removed the A.I.R. pipes and related parts. If I do remove the A.I.R. manifolds I have some other ones to use so as to make it easier to convert it back later.
:hail: TIA
Nathan
Old Sep 17, 2002 | 02:05 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
the way i understand it, it only robs around 5-7 hp. if you dont have emissions where you are, yank it out. i would pull mine out, but i have hardcore sniffers in nj.
Old Sep 17, 2002 | 02:25 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I dont know how much it does for emissions, but I can sure get to the plugs and plugwires now. I removed my a/c compressor and my smog pump. And the a.i.r tubes are history.
Old Sep 17, 2002 | 02:35 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
If you have the time I would, but I removed mine when I installed my headders. Just make sure you seal the manifolds up, the sound gets old after a while.
Old Sep 17, 2002 | 04:10 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Where? On the intake manifold or something?
And is there a tech article somewhere describing what all can come off?.....like that mushroom looking thing with 3 hoses in it....what the hell is that?
Old Sep 18, 2002 | 10:06 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
yes you can take the "mushroom looking thing" off. Also take the smog pump, all the hoses running to it and the air tubes also.
You will have to get a shorter belt. You can also remove the a/c compressor and its componets. But you will have to have a a/c delete pulley from GM.
Old Sep 18, 2002 | 11:55 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
If you have a good running engine you can pass emissions without the AIR pump.
Old Sep 18, 2002 | 03:36 PM
Car: 91 RS
Engine: 350 TBI
I would prefer to keep my heating and AC capablities, so I won't go quite that far. However, when I was checking it all out yesterday, it looked as though there was some hose coming out of the back of the serpentine setup (not sure of the component), but can I just plug that hose or something (although it looks like I'll need something the size of a golf ball to do it)?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
89fast5oh
Sep 8, 2015 09:55 AM
