header gaskets
Old Nov 30, 2002 | 01:51 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
header gaskets
I am looking for recommendations for header gaskets (at the heads not the y-pipe).
Don't mind spending extra for a quality piece either. Anyone have any suggestions ?
thx in advance,
RP.
Old Nov 30, 2002 | 02:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Aluminum or copper, about $40, but they're reusable.
With my new aluminum heads I'm gettin aluminum ones, I don't want to risk another blown gasket and burnin the heads.
I think Percy's makes the aluminum one..
Old Nov 30, 2002 | 05:21 PM
darbleinad's Avatar
Car: 84 Trans Am
flowtech "realseal". dead soft aluminum construction. reusable. they are great. they will work very good with those flowtech you have palric. they work great on my flowtechs. i think i paid 62 dollars for mine....i cant quite remember, but it was right around that. i put them in when i swapped engines, no leaks at all. i also have the "realseal" collector gaskets. i would go for these.
Old Nov 30, 2002 | 06:12 PM
scrawnywhiteguy's Avatar
Yeah definitely the Percy's Aluminum ones. They're expensive, but if you have alot of power they're worth the money. A guy I know from Cali has an amateur race team, and his race car is a 327 makin about 500-525 HP, he's been usin the aluminum ones for years, and hasn't blown one yet.
Tim:rockon:
Old Nov 30, 2002 | 08:01 PM
ctandc's Avatar
Too much advertising hype........
Just wrapped up my header install in my IROC, and just as every other header install I've done, I have NO exhaust leaks underhood.
Go to a parts store and get TWO sets of Fel Pro replacement STOCK exhaust manifold gaskets. Now just use one set PER header. Put each matching pair together, metal side to the head and metal side to the header. Loctite the bolts, and you have NO LEAKS, and you just spent less than $20.
HTH
Old Nov 30, 2002 | 09:45 PM
TBI305Camaro's Avatar
I like the percys dead soft...I have them. Before I used the ones the hooker headers came with...blew 2 sets. I havent had a problem with the percys yet.
Old Dec 1, 2002 | 05:49 PM
palric's Avatar
Thx Brad I didn't know flowtech made gaskets too -- I'll check 'em out. Mind if I ask where you got them from ?
thx,
RP.
Old Dec 1, 2002 | 06:02 PM
darbleinad's Avatar
Car: 84 Trans Am
i got mine at jims speed equipment here in london. any speed shop and likely crappy tire should be able to get them for you. mine only took like a day and a half to arrive.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
