TES headers
Old Apr 10, 2001 | 11:50 AM
89FormulaL98's Avatar
TES headers
i am planing on getting some headers installed on my car, Edelbrock TES headers to be exact. Its hard to find shops that will do it and i dont want to get ripped off.
I dont have an A/C so I dont thing it would that huge of a job (only reason i dont just do it with a friend is because i want it welded) how much should i be looking to spend with out getting ripped off?
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
more to come soon.....
Old Apr 10, 2001 | 11:55 AM
IROCZ88's Avatar
Don't weld it! It will be a pita to take off if you have to. The headers are a complete bolt on kit. Just put an exhaust clamp where they mate to the cat. You'll see no problems and it will save you hundreds of dollars doing it yourself.
Sorry, but I have no respect for people who just buy parts and pay people to put them on.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 10, 2001 | 01:41 PM
i really would want to do that but....
in the summit catalog i would be ordering the headers from, for the dual catalyst exaust (the exaust i have) there is cutting and welding to attatch to the original exaust
Old Apr 10, 2001 | 02:55 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I have the edelbrock headers w/ dual cats, I was looking for system that replaced from the header back the intermediate pipe. the only place that sold a replacement for that little y-pipe that connects the rear of the cats is flowmaster. I wanted to get rid of the stock Y-pipe but no company had a system like that.every system I found I had to still use the stock Y-pipe assembly.
Old Apr 10, 2001 | 06:17 PM
i still need to cut and weld
Old Apr 11, 2001 | 07:28 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Suggestion: Do the actual header install yourself ,then take it to a muffler shop and have them do the necessary welding to attach the pipes from the headers to the cats. In doing the headers yourself you will also find that you will need to get a new set of plug wires with all 90 degree boots and that this is a great time to change the plugs and O2 sensor as well.
NOTE: Use plug wires that are universal so that you can make them only the length you need for routing them around the header tubes.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Apr 11, 2001 | 01:06 PM
well i just changed all that stuff last summer i just spent 50 bucks on taylor wires and those wont fit?! there are only 5,000 mile on the plugs too, but i spoze as long as i have everything apart it might make sense. Will i have to do any cutting to get the stock manifolds and y pipe off? and once that stuff is off, how easily do the headers bolt on?
Old Apr 11, 2001 | 01:07 PM
i recently did the O2 also
Old Apr 12, 2001 | 08:39 AM
Mongoose's Avatar
Car: 90 Formula
Cutting will be required to get the cats off(dual cats only) once the Y pipe/cat assembly is off the car. As for the manifolds,just follow the instructions for the most part with one notable exception: remove the starter and move the passenger side header in from underneath. Unless you're willing to loosen the engine mounts and jack the engine up just to go in from the top,it's the easiest way. Just be aware of the fan switch located between #6 and 8 sparkplugs. I broke mine during the first header set and when I replaced it on the next set it was anti freeze city!
Old Apr 12, 2001 | 11:18 AM
so i can get the manifold off myself with out cutting anything? and i can leave everything else to the muffeler shop?
im sorry im actin like a dink, but ive never done anything like this before and i dont wana screw somthin up
NZKnight
Oct 15, 2015 02:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
bamaboy0323
Sep 12, 2015 07:14 PM
