Hooker cat back
Old Dec 31, 2002 | 01:03 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Hooker cat back
Will this hooker cat back fit on my 82 z28? Part number HOK-16823 on summit.
http://store.summitracing.com/partdetail.asp?part=26682
Old Dec 31, 2002 | 03:08 AM
MdFormula350's Avatar
Specifications:
* Intermediate pipe: 3 in.
* Tail pipe diameter: 2 1/2 in.
* Dual tail pipes out the rear under the bumper
* Does not fit dual catalytic converter vehicles
* Fits with engine codes G,F and 8
looks like a nice system, you might have to do some work to get it to fit on the cat..
This Hooker Super Competition high flow cat-back exhaust system aids in performance gains from modifications such as cams, intakes, throttle bodies, headers, etc. It uses large diameter, mandrel bent, 16-gauge aluminized tubing for maximum efficiency (lowest backpressure) and longer life. This system is designed using flanged construction (where applicable) and uses existing stock hangers for easy installation. It exits in the stock location.
Old Dec 31, 2002 | 05:46 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I just came into this post to say FLOWMASTER.
Thanks for reading!!
Old Dec 31, 2002 | 10:00 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
I hopefully wont have to run a cat if I can register my car at my uncles house(no emissions) I'll also be running hedman shorty headers.
Old Dec 31, 2002 | 02:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The only difference among the different part #s there, is the way they hook to the cat. The $200 system has a rectangular flange on the I pipe that hooks to the cat. I ordered that one and had it cut off and welded.
Old Dec 31, 2002 | 04:00 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Mark,what is the part numer for the one that you ordered?
Old Dec 31, 2002 | 04:05 PM
Jeffbird's Avatar
high
Old Dec 31, 2002 | 04:14 PM
Car: 99 Formula
Axle/Gears: 342
sorry don't have the catalog here with me, it's the $200 one in Jegs, listed for the 83=85 HO engines.
Old Dec 31, 2002 | 09:21 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Does that have the 3 in. I pipe?
Old Jan 1, 2003 | 12:37 PM
Car: 99 Formula
Axle/Gears: 342
yes, it is 3'' mandrel bent.
Old Jan 1, 2003 | 12:53 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Ok, thanks.
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 22, 2015 07:49 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
