LS1 header question
Old Jan 28, 2003 | 09:27 AM
mess21's Avatar
LS1 header question
will the 1 3/4" SLP non-emissions headers for the TPI 350 bolt up and fit into a thrid gen with an LS1?? If not what shorties will 4th gen headers?
Old Jan 28, 2003 | 05:04 PM
Brett Gutshall's Avatar
LS1's have the exhaust ports equally spaced out on the heads, just like the old big blocks. So no TPI or other traditional small block headers will work.
Old Jan 28, 2003 | 10:44 PM
mess21's Avatar
then what headers will fit into a third gen with an LS1
Old Jan 28, 2003 | 10:53 PM
BikertrashDude's Avatar
any header that fits a 4th gen LS1.......
Old Jan 30, 2003 | 12:09 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
how do you knwo for sure?
Old Jan 30, 2003 | 04:10 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Check the engine swap board, I think only the stock LS1 manifolds or something custom.
I think Ford SB are equally spaced so maybe a mustang headers with some bolt holes drilled in them may work. Don't know about that though.
Old Jan 30, 2003 | 07:59 PM
onebadwagon's Avatar
the small block ford headers with different flanges would bolt up, the ports line up perfect. but i dont know about chassis clearance,
adam
Old Feb 4, 2003 | 06:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The LS1 headers look just like big block headers because they have the equally spaced tubes. You just have to look for F-body headers '98+ or Corvette headers '97+
Those cars had LS1s
Old Feb 6, 2003 | 01:55 PM
Momar's Avatar
Yes but will they clear a thirdgen. I know that you cant fit almost any header in a thirdgen unless it is made for one.
Ben
Old Feb 6, 2003 | 02:07 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
From what I've read, the stock LS1 manifolds are the only ones that'll work.
This guy used LS1 manifolds and a modified MAC Y pipe. It still hauls *** with exhaust manifolds!
Old Feb 6, 2003 | 10:30 PM
Needs to be mentioned that their manifolds are exactly like ours. They are "logged".
Old Feb 6, 2003 | 10:44 PM
Engine: LS7
The stock LS1 manifolds are about 10 times better than our stock IMO. I've had one in my hand for about an hour trying to get a broken stud out of it yesterday. (roommate has an '02 WS6)
The "log" part angles down maybe 30* below the exhaust ports and is cast very nicely compared to anything on my 2 thirdgens. Quite smooth and not much to port IMO, unless you wanted to make things larger, nice smooth transitions. I bet they make can make 350+ RWHP with stock manifolds N/A.
Old Feb 7, 2003 | 03:55 AM
Bill V's Avatar
We're putting a ls1 into a 85 Camaro. Bought SLP long tube headers, and they don't fit. We had Street and Performance build us a set, but they're not equal length. We did get them coated though. I'd stick with the manafolds, or a set of shorties.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
