Experience with Dynomax dual exhaust kit?
I just got a dynomax cat back plus the cat, Im not sure of part#, but it kicks @55. I can really feel the difference and
it seems to widen my power band.
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,Dynomax Cat & Cat Back System
www.camarors.4t.com
Jeff
www.camarors.4t.com
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
dual exhuast kit? you mean as in true duals? or dual tips, or dual mufflers off a single pipe?
Wide Open Till You See God...Then Brake
i believe this is the same setup i'm wondering about in jeg's, its referred to as header duals, but they will not bolt up to a certain # dynomax headers. any info is greatly appreciated.
'84 Berlinetta, LG4, 700R-4, starwars interior, falling headliner, T/A t-handle shifter, trans cooler, more to come in time and $$ www.hipergp@aol.com
this system confuses me too. When I tried to contact dynomax, they just kept telling me about their catback systems for my app. Pissed me right off. Anyway, these dual kits from what I know are desgined to be hooked to their cyclone or blackjack shorty headers. These systems are 2 1/4 pipes that are not mandrel bent and they are designed to work with Dynomax's turbo mufflers. All I want to know is if these systems exit out the back of the car or in front of the rear wheels. I can't seem to figure it out.
Re: Experience with Dynomax dual exhaust kit?
just incase theres confusion on this kit (the dynomax kit from jegs), that require a certain header: they are True duals. the only true duals for third gen camaros ive seen. unless ofcourse u have someone do a custom job for you or do it yourslf. it replaces all the way up to the headers. so you have to fit the two pieces of pipe they give you where the ypipe use to be, and it's the two all the way back through the driveshaft tunnel (kinda like stock exhaust, with 2 mufflers at the end of the car. it's kind of a tight fit and takes time to get it sitting right and snug. since it takes up more room being tru duals. But i'm liking the setup. if anyone else knows of other true dual header back kits for these cars, please let me know
-X-
-X-
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
there are TONS of pics of this setup on the dual exhaust sticky at the top of the exhaust forum.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
