ok i've got $550 bucks....i need 3" collectors
Old Oct 10, 2001 | 06:26 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
ok i've got $550 bucks to blow on an exhaust .....i need some headers w/ 3" collectors....and a catback exhaust...not worried to much about the catback quality just yet....preferably from summit....any suggestions....seems like a lot of headers are stock oem connectors???(2.5")....
thanx..........
just ansking for any tips or advice...not asking you to do the dirty work of setting my exhaust up for me...
thanks
rob
Old Oct 10, 2001 | 08:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would get the Hooker cat-back, but not sure if summit sells it, I know jegs does. With the money you would have left you can rule out SLP headers, I have the Edelbrock and it was an easy install.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 11, 2001 | 04:06 PM
Car: 1983 Z28 Clone
Transmission: TH350
yeah i was looking at edelbrock tes..but the connection to the cat is only 2.5"...i only have a mild 305......should i just go with 2.5"
rob
Old Oct 11, 2001 | 04:33 PM
Car: 99 Formula
Axle/Gears: 342
I think some of the Edelbrock's due come with a 3" depending on the part #, something you might want to call summit about.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Oct 11, 2001 | 04:50 PM
Tas's Avatar
Tas
there are 2 main versions of edelbrocks for us. 1 has 2.5" pipes going to single 3", the other is the TBI one that has a heat riser for the air cleaner, 2.25" pipes going into a single 2.5" cat pipe.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 12, 2001 | 06:26 PM
Car: 1983 Z28 Clone
Transmission: TH350
OK I CALLED a local speedshop..they said...maybe i could try adding an 86 camaro y pipe and headers..cause they would be 3 "... i called summit...they said mostly everything is 2.5"??????
but.. would an 86 headers and y pipe fit my 83 ??? thanx
Old Oct 15, 2001 | 11:51 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
My TES system has dual 2.25" 'collectors' and Y-pipe 'intermediate pipes' going into a single 3" pipe that goes to the converter. not sure who you're talking to about this stuff or what they are smoking....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 16, 2001 | 04:05 PM
Car: 1983 Z28 Clone
Transmission: TH350
i called summit and sent them an e mail...they said the y-pipe is different on an 86 and up and it would not fit my 83......from edelbrock "Unfortunately the header # 6872 has a different Y-pipe and cross over pipe and these will not work on your 83 model." soo.. will it or not??????
rob...
PurelyPMD
May 5, 2016 04:57 PM
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
bamaboy0323
Sep 12, 2015 07:14 PM
