plug boots hitting headers...
Old Mar 24, 2003 | 04:38 PM
gtabadboy's Avatar
I have the hooker long tube supercomps and had to buy short plugs. One of my plugs #7 is hitting the header. I bought the plug shields--expensve ones for 90 a set, but I started my car and saw the plug arcing out on the headers the other day. I have two more options, one get header wrap and two bang a dent in the header. Denting is the final option. Will the header wrap prevent the arcing- does it conduct electricity? Any suggestions on a brand that will withstand the high temp of the headers?
Old Mar 24, 2003 | 05:31 PM
25THRSS's Avatar
Are the plug boots 90 degrees? If not get some 90 degree plug boots.
Old Mar 24, 2003 | 06:06 PM
Marc 85Z28's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=148210
Goto Installation Note #18
Old Mar 24, 2003 | 06:49 PM
gtabadboy's Avatar
Yes they are 90 degress...Im wondering if mabe a 135 degree boot will work?
Old Mar 25, 2003 | 04:19 PM
Doogie92Z28's Avatar
get soem accell header plugs...they are shorter then normal ones so u get osme extra clearence...the autozone by my house carries them
doug
Old Mar 25, 2003 | 05:20 PM
rezinn's Avatar
1) buy shorter plugs
2) try different angle plug boots
3) find better sleeving, I had a similar problem and bought some sleeving that was $13 for two fitted 6 or 9" 1500 degree pieces, and it has worked fine for two years, many plug changes, and two engines.
Old Mar 25, 2003 | 05:45 PM
gtabadboy's Avatar
I bought the shortest plugs possible for my application and Dart Pro 1 heads.. I also bought the boot shields a set of 8... I may try a 135 degree boot, 90 and 180 dont work well.
Old Mar 25, 2003 | 07:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Put a little header wrap around them. I've heard that can help.
Old Mar 25, 2003 | 10:20 PM
gtabadboy's Avatar
Just ordered my header wrap today. I hope this will work.
Old Mar 25, 2003 | 10:42 PM
Momar's Avatar
I would consider shortening the spark plug like phil87iroc did. I think that this would be the best solution.
Ben
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 5, 2015 03:55 PM
rjcme
Sep 5, 2015 01:23 PM
