305 to 350 exhaust?
Old Dec 13, 2001 | 12:45 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
305 to 350 exhaust?
I currently have a 305 in my Bird. But I was thinking of swaping it for a 350. I have already put headers on my 305, which was probly a big misteak since I want to do this now, but would the headers for the 305 and the custom Y-Pipe I had made work on the 350? I'm guessing the headers could possibly work, but I don't know about the Y-Pipe.
Thanks for any info you can give me on this. Sorry, I'm sure this has been asked before though.
Old Dec 13, 2001 | 01:06 AM
Tas's Avatar
Tas
They'll work fine any they have to be better than stock manifolds anyway so don't worry about it
-Tas
'89 Formula WS-6 made in Van Nuys, CA, U.S.A.
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 13, 2001 | 10:58 AM
TZFBird's Avatar
Engine: 327
I was thinking more in terms of size though, such as bolt patterns, and the size of the block fitting between the headers and Y-Pipe. But, thanks for your info. I'm sure they are very close.
1988 Firebird TBI 305 (Beast hahah, right)http://www.geocities.com/tzfbird/tzfbird.html
Mods:
Dynomax headers, Custom Y-Pipe, 13X2.5 Open Element, Sanding/Painting Wheels
Old Dec 13, 2001 | 02:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bolt patterns are identical. Unless you are getting some sort of maxed-out aftermarket heads, the size won't be an issue. If you have a 2-1/4" minimum downpipe on each side going to a 3" pipe to a 3" cat, you should be fine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 13, 2001 | 03:55 PM
TZFBird's Avatar
Engine: 327
I'm not sure what size the custom Y-Pipe is, but it is pretty damn small. I think I messed up when I went in to have it made. I failed to specify a size, so I pretty much killed myself there. Anyway, it's probably a 2-1/4. But, it comes right out of the headers, turns, and the two sides hookup, then enter the cat. It's got a lot better flow than the stock pipe I'm sure. It's 2-1/4 all the way back. Will a 350 work with that, or am I going to have to get all that redone? I will most likely be getting a cat-back sometime in the future. But I don't know about the cat. Is that going to need a change as well?
Mods:
Old Dec 13, 2001 | 06:11 PM
five7kid's Avatar
2-1/4" all the way back is about one side's worth for a 350.
You'd be better off getting a minimum of 3" when both sides come together and not going any smaller until it splits again.
Old Dec 13, 2001 | 09:59 PM
TZFBird's Avatar
Engine: 327
So, basicly what you are saying is that I can leave the Y-Pipe, but just put on a 3" cat and cat-back? From the point where the two sides come together and the cat, there is maybe 6 inches of 2-1/4, then it goes into the cat.
Old Dec 18, 2001 | 12:47 PM
five7kid's Avatar
2-1/4" is only good for one side. After the two are joined, you want a minimum of 3". So, have the y-pipe modified so it does not have any 2-1/4" after the two sides are joined.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
