Torque the headers?
Old Sep 9, 2003 | 03:48 PM
PsychoGTA's Avatar
Torque the headers?
How much lbs should i torque my headers?
Peace Out,
PsychoGTA
Old Sep 9, 2003 | 04:28 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
I believe it's 25 ft lbs....
Old Sep 9, 2003 | 07:44 PM
25THRSS's Avatar
go from the inside out too.
Old Sep 9, 2003 | 10:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Crawl inside the motor?????
Old Sep 9, 2003 | 10:46 PM
darbleinad's Avatar
Car: 84 Trans Am
heheheh....he means the bolts closest to the center primary and tubes and work your way out from the centre.......
i know you already know this...so....hhaaha
but as for the torque, good luck getting a torque wrench in there...might be able to get a few...but you wont get them all. just get them as tight as you can...drive the car for a day or two and then retighten....repeat this procedure as necessary
Old Sep 9, 2003 | 11:23 PM
25THRSS's Avatar
hahahaha, funny, but darbleinad knows what I meant.
Old Sep 10, 2003 | 12:35 AM
PsychoGTA's Avatar
thanx a lot.
Peace Out,
PsychoGTA
Old Sep 10, 2003 | 12:46 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
lol... that was funny.
A tip that has worked for me.. be sure to put a thin coating of ultra copper RTV on the gaskets before putting them in as well. It's kept me from having a (standard) gasket ever blow out even with loose bolts. Might just be my luck too but, every little bit helps.
Old Sep 10, 2003 | 06:41 AM
darbleinad's Avatar
Car: 84 Trans Am
thats also a good suggestions, there Deadbird. i have used the ultracopper RTV on collector gaskets on headers that have warped flanges and it worked quite well.
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Ragtop Man
Sep 12, 2015 12:23 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
