removing SMOG equipment
Car: 1989 trans am
Engine: 357sbc
What do i need to do to remove the smog equipment from my LT1?? here in minnesota there are no emissions tests so its ok... thanks
Car: 1992 RS
Engine: Briggs and Straton
Smog Removal
There is a post under the tech articles that shows how to remove smog pump with only re-routing your belt. You will need a different size belt. I just made that change this weekend. I bought a pulley from TA Creations for $50.00 plus $26.00 for the belt. The entire job took 15 minutes and the power is very noticable. Anyway 10 minutes after I clicked buy now I found the thirdgen.org article on how to do the same thing for the cost of a belt and a different pattern. Good Luck
Car: 1989 trans am
Engine: 357sbc
hey man i read that article and i don't know if that will work for a LT1, pulleys and what not are in different place than what are on my engine, does anyone kno if that tech article will work or if there is another way? THANKS
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No they are different set-ups. Go over to www.camaroz28.com and search about air pump and egr removal. They will tell you the correct way to do it.
Car: '90 RS
Engine: 377 LSX
I just checked and got a lot of results. Just go to camaroz28.com and go into the message boards. Click on search and type in 'air pump removal." I got about 10 hits on my frist try. Then try the same thing only about EGR removal, or whatever you want off of the front accessories.
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
Could you post pics and supply details on how and what parts to remove when eliminating the AIR pump.
Thanks in advance.
Thanks in advance.
Car: '90 RS
Engine: 377 LSX
Thanks in advance.
Thanks in advance.
