2055 or 2460?
Old Feb 16, 2004 | 08:22 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
2055 or 2460?
Had a set of hooker Comp headers for a while, now it's time for another ypipe. The custom 3" one sucks and I want something easy. How do I tell if the headers are the 2055's or 2460's?
Here is a pic <img>http://images.cardomain.com/member_i...02_16_full.jpg</img>
Old Feb 16, 2004 | 09:41 PM
25THRSS's Avatar
They are the 2460. The 2055 has a different collector and comes with an awesome y pipe.
Old Feb 20, 2004 | 08:52 PM
RICHRAD's Avatar
Got a pic of that y-pipe... dude
Old Feb 21, 2004 | 08:55 PM
Engine: LB9/383
me? no pic of the ypipe. Nothing special, just a piece of crap that a lockal shop did for me. Ugly as sin. Full 3" from the collectors. I'll take some pics when I take it off. I was hoping I could get a bolt on pipe, but I guess I'll have to weld up one on my own. thx.
Old Dec 11, 2007 | 11:29 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: 2055 or 2460?
Sorry to bring up an old thread, but is there 2055's that do not come with the smog provisions?
Old Dec 11, 2007 | 11:54 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: 2055 or 2460?
No but you can cut the tubes off and weld them up, thats what I did.
IMO the 2055's are the way to go because you get that nice 3" collector Y-pipe so you can run a 3" exhaust all the way back.
You can get some other cheap headers and have an exhaust shop fab up a Y-pipe for you but then it is about the same cost as just buying the 2055's.
Old Dec 11, 2007 | 12:14 PM
BCdawg57's Avatar
Re: 2055 or 2460?
Would i be better off to buy them painted and cut/weld the tubes then have them coated or is there a way around that, so i could just buy them coated? I don't want bare spots on the tubes where the smog used to be.
I suppose i could just use header wrap on painted ones. That wouldnt look too bad.
thanks
Old Dec 11, 2007 | 01:13 PM
4playta's Avatar
Car: 1984 Trans Am
Re: 2055 or 2460?
thanks
I didnt coat mine, I cut off the tubes and welded them and used an angle grinder to clean them up, then I painted them with high temp paint. You could do the same but instead of painting them have them coated.
Old Dec 12, 2007 | 12:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 2055 or 2460?
The 2055 part number means 50-state legal Hooker headers with the AIR tubes. They're required by FEDERAL law to be there, on a street car.
Do not use header wrap, that stuff sucks. Thermal coating is the best way to go for long lasting headers.
Old Dec 12, 2007 | 11:05 AM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
Re: 2055 or 2460?
Hooker does make a y-pipe for the 2046 it's like 240 bucks though. It's jegs PN
520-16767. Not sure if it's a 3'' or 2 1/2'' though.
It's has 3'' collectors and a 2.5'' outlet according to summit. Might be worth buying the 2055's and grinding off the air tubes.
Last edited by EndlessSummer85; Dec 12, 2007 at 11:09 AM. Reason: Automerged Doublepost
Old Dec 12, 2007 | 11:20 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: 2055 or 2460?
SUMMIT RACING has the HOOKER Y-PIPE
3" Inlet...flared down to a 2.5" This can also be used to delete the cat with a nice finish...
http://store.summitracing.com/partde...+&autoview=sku
Old Dec 12, 2007 | 12:11 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: 2055 or 2460?
I just e-mailed hooker to see if I can order up the y-pipe from them...the 3" to cat y-pipe for the 2055's
Lets hope a good response....because then im just going to buy the 2460's like I had intended and hook up the 3" to it...HELL YEAH.
Old Dec 12, 2007 | 12:45 PM
Re: 2055 or 2460?
Let me know how that goes and if it will work with the 2460's I'm in the same boat.
Old Dec 14, 2007 | 01:05 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: 2055 or 2460?
Just got a response back from HOOKER TECH.
The 2055 y-pipe is NOT sold separate.
Nor does the 2460 y-pipe bolt up to the 2055 headers.
So it looks like custom it is
Old Dec 15, 2007 | 09:43 AM
Pat Hall's Avatar
Re: 2055 or 2460?
thanks
Jet-Hot can remove the tubes, weld the holes shut, and coat them afterwards. I bought a set of 2055's from them brand new without the tubes, and the welds are nice and neat looking, and fully coated. The 2055's are hard to find in their online header catalog, but they do have them available. Probably easiest to call or email them to request some. Here's a pic of mine.
Old Dec 15, 2007 | 09:46 AM
Pat Hall's Avatar
Re: 2055 or 2460?
Oh, here's another pic for you guys that shows the y-pipe that comes with the 2055's.
Old Dec 15, 2007 | 10:03 AM
Re: 2055 or 2460?
Damn that looks sweet coated!!!! How much did that run you??? For them to cut off the air tubes weld em and coat em?
Old Dec 15, 2007 | 10:23 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 2055 or 2460?
I make these headers.
Wouldn't you rather have these:
Old Dec 15, 2007 | 10:42 AM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
Re: 2055 or 2460?
soon real soon. there is no better header option, period.
Old Dec 15, 2007 | 11:39 AM
Pat Hall's Avatar
Re: 2055 or 2460?
Not sure if they charge any additional to cut the tubes and weld up the holes, but the coated headers are pretty spendy. Somewhere in the range of $700, give or take some, the last time I checked. I got really lucky though. A guy on the classifieds here gave up on his thirdgen project, and sold me the set in the pics for $460 shipped.
Old Dec 15, 2007 | 09:30 PM
Re: 2055 or 2460?
Yea right on sometimes you get lucky.
Dyno Don those look pretty sweet too, I just don't have that much for headers...
Old Dec 15, 2007 | 09:59 PM
Firebat's Avatar
Re: 2055 or 2460?
On the 2460 y pipe, I cut off the 2.5" elbow/bend on the very end of it and had a 3" elbow welded on...
So, it has 3" inlets and a 3" outlet on the ypipe.
Old Dec 16, 2007 | 12:49 AM
Kevin91Z's Avatar
Re: 2055 or 2460?
Then you should save your money. Doing something cheap is not doing it right. Just look at all those cheap toys from China.
Old Dec 16, 2007 | 05:15 PM
Re: 2055 or 2460?
Yep, just gonna have to wait I guess....
Old Dec 16, 2007 | 06:11 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: 2055 or 2460?
the coated 2055's look real nice, but i was surprised looking at the pics that jet-hot left the nipples on the tubes.
for 700, you think they woulda taken the time to weld/cut them down flat and smooth things out a bit.
Old Dec 16, 2007 | 06:56 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: 2055 or 2460?
It's the only way to go IMO...
Old Dec 16, 2007 | 08:09 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: 2055 or 2460?
Looks VERY tempting! Are they stainless?
Old Dec 17, 2007 | 03:01 AM
Pat Hall's Avatar
Re: 2055 or 2460?
That's ok, I like nipples!
Old Dec 21, 2007 | 01:09 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: 2055 or 2460?
How much?
Because Edelbrock has these:
http://store.summitracing.com/partde...DisplayPrice|0
Old Dec 21, 2007 | 01:29 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: 2055 or 2460?
How much for this setup with y-pipe/ Badman
Old Dec 21, 2007 | 10:57 PM
Kevin91Z's Avatar
Re: 2055 or 2460?
How much?
Those Edelbrocks have tiny outlets and are made for the tiny exhaust that comes on TBI cars. You want to at least get TPI headers with the larger outlets to go with the 3" exhaust you should have on a TBI car. Putting those things on is about --><-- this much better than what you have now.
Don's headers are 1 3/4" to fit the larger, raised exhaust ports on today's aftermarket heads. Send him a PM for the details.
Old Dec 22, 2007 | 07:54 PM
Re: 2055 or 2460?
Hawks third gen has the ypipe for the 2460's for $200 not a bad deal the cheapest I've seen yet... And it's from a sponsor here so that's always cool!!!
canadiangta
Aug 19, 2003 10:48 AM
25THRSS
Mar 15, 2003 08:49 AM
jamesbob02
Jan 22, 2003 10:24 AM
redcamaro83
Nov 30, 2002 12:20 PM
Steve89GTA
Feb 19, 2001 04:41 PM
