Hooker cat-back question
Car: 1986 Trans Am
Engine: LG4 305
Hi everyone, i was wondering about the Hooker cat-back systems that i saw on the Jegs(www.jegs.com) website for our cars. I saw a system for 1983-92 non H.O. 305 Engine code H and E Part #520-16820 for $262.99. I then saw a 1983-85 for engine codes G, F, and 7 Part #520-16822 for $207.99. Now my question is, can I use the system for $207.99 on my 86 trans am with the engine code "H"??? Is it worth getting the less exspensive one and maybe doing a little pipe fabbing if I have to? I was just wondering because I wanted to get it but wasn't sure if I could just get the cheaper one and be in the clear?
Any input is appreciated,
Tony
Tony
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The difference is in the way they attach to your cat. The more expensive system has a 3" to 2.25" reducer so that you can attach the cat back to the stock cat. If you want a tru bolt on and are not changing headers or your cat at this time I would get the system that matches your engine code. That way you can be sure that it will bolt right up without any fab work.
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
hey shifty...I decided that I am gonna get the hooker system...everyone talked me out of the borla one. But I got new hooker 2055s with Y pipe and a new 3in universal carsound cat(Thus no flanges). My car is an 84 H.O., Engine code G. So I know that I need the cheaper one, but is it flanged? Do you know if you have an option when ordering?
Car: '90 RS
Engine: 377 LSX
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I bought the Hooker for the TPI car and it had 3 inch all the way and the part that goes to the cat wasn't tapered down to 2.x inch, it was 3 all the way. The cat part flared out like the openings on the Hooker y-pipe that go to the headers. If you can weld get the cheaper one then cut your flange off your stock and weld it to the 3 inch hooker pipe. Otherwise the pipe bends are identical, I am not sure about the hangars though, but like I said if you can weld no probs. I made the mistake of getting the 267 one and I have no cat, just a 3 inch straight pipe and summit cutout and ended up cutting and welding anyway, damn it, I should have got the 207 one, oh well.
What part number is it for the 350 TPI cars?
The only ones they have listed in the JEGS catalog are...
16820..F-Body 305 83-92 (H/E) $265.99
16822..F-Body 305 HO 83-85 $207.99
16823..F-Body 305 TPI 86-92 $262.99
Also, what is the H/E thing?
Car: '90 RS
Engine: 377 LSX
So then the only difference between
is that the TPI one does not have a reducer for the cat; it is just completely 3in? Then all I would have to do is cut the flange?
