Headers
Old Mar 9, 2004 | 12:19 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
Headers
I know this topic has been drilled into the ground, sorry. But what headers and y-pipe should I buy? I have a 92 Camaro stock 305 TBI automatic.
Old Mar 9, 2004 | 12:30 PM
Car: 92 Camaro
Or do I even need a y-pipe?
Old Mar 9, 2004 | 12:58 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Personally for a 305, I really like the Hedman LTs (1 5/8" primaries, 3" collector). Buddy added those to his TA and picked up .4 in the 1/8 just w/ the headers and a custom y-pipe. You will have to get a shop to make a y for it though, cause it doens't come w/ one. He used 2 S-Xtensions and a Flowmaster Y, then got the place to bend 2.5" tube and weld it all up...
Old Mar 9, 2004 | 01:56 PM
davehamilton's Avatar
It is very hard to get long tubes in a third gen and have a y-pipe fabbed due to the limited space. You get get basiclly the same performance from the Hedman 68470 shortys and matching y-pipe. And they are basiclly a direct bolt up to the stock cat. Which makes them a very popular setup. We also carry these with AIR.
We can weld in an o2 bung prior to coating also. If you wish for the LT's we also carry these at a discount for the members on the boards here.
Old Mar 9, 2004 | 02:13 PM
Car: 92 Camaro
Dave, what all would I need? And do you carry all of the parts I would need?
I was thinking of dumping right infront of the rear tires, any advice on how I could set that up?
Old Mar 9, 2004 | 02:14 PM
biff85ta's Avatar
Car: 04 Vette
My Lt's and y pipe fit just fine.
Old Mar 9, 2004 | 02:34 PM
We have a guy that just bought a set of Hooker 2460's and is dumping at the rear wheels with no cat and he had his local exaust shop fab up the pipe which most shops won't do without cats. We also, as the other guy with us here stated, Have hed people do it with the long tubes. But again you have to get the tubing fabbed up.
With the Hedman #68470 we carry everthing you nedd down to the cat, Beyond that you can have it fabbed to the rear wheels.
It's pretty much all a matter of opinion which is the best setup for a street car.
Old Mar 9, 2004 | 02:35 PM
Hey Biff howd those headers look???
Old Mar 9, 2004 | 03:12 PM
Car: 92 Camaro
How much are the 68470's from you? What parts would I need to be able to dump infront of the rear wheels on both sides and how much would it run me?
Old Mar 9, 2004 | 03:40 PM
Hello, The Headers are $239 AND the y-pipe is $85 it is an additional $50 to have the y-pipe coated.
You are goind to need some bends and some straight pipes to complete the catback which are available through JEGS. or jus take it to the exaust shop and have them finish it out they will have the necessary piping.
Old Mar 9, 2004 | 03:46 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Here are a few pics of Biff's stuff...
https://www.thirdgen.org/techbb2/sho...hreadid=227025
Old Mar 9, 2004 | 03:58 PM
biff85ta's Avatar
Car: 04 Vette
Here is a link to some older and better pics.
https://www.thirdgen.org/techbb2/sho...hreadid=206181
Old Mar 9, 2004 | 04:00 PM
biff85ta's Avatar
Car: 04 Vette
I wish the had been coated just because now the look like crap because of some rushed prep work before paint. I painted the with some hi temp stuf I got at advanced and anywhere the header was clean and free of the old pain it has held up well.
Old Mar 9, 2004 | 04:56 PM
I thought we coated yours. Well we can set you up with a good deal on the coating of your choice. Also send me some pics of your setup I am curious to see it!!!(exaust with Lt's)
Old Mar 9, 2004 | 07:24 PM
biff85ta's Avatar
Car: 04 Vette
As sppn as I can get it high enough up in the air to get some good pics I will send you some. I would love to get them coated but the car is my daily driver and I can't afford to have it down gfor that long.
Old Mar 9, 2004 | 09:17 PM
If you can send them Next day air Sat delivery on a friday I can coat them Sat and Sun and send them back on Mon Next Day Air and if you PM me I can Can help U on the cating price a little more to make up 4 the shipping. Like Spring break or labor day weekend. We always try do help you guys the best we can and try to make a little @ the same time.
Old Mar 9, 2004 | 09:46 PM
biff85ta's Avatar
Car: 04 Vette
I get my days off separate from each other and what I have is good for now. Within the next couple of years I should be doing a motor swap and when I do I will probably raplace them with new ones and I will get a hold of you.
Old Mar 9, 2004 | 10:51 PM
No Problem if I take in a used set on trade ( in decent shape) then I will let you know and coat them and trade you out for your used ones as in no down time for the same product!
Thanx
ACS headerz
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
