Glowing headers
Old Jun 16, 2004 | 04:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Glowing headers
Just wondering if anyone elses headers glow red hot or have in the past glowed? What did you do to stop the glow? I believe it's from running rich?
Old Jun 16, 2004 | 05:22 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
rich=cool
lean=hot
and no, my headers don't glow
Old Jun 16, 2004 | 05:30 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well my headers glow but that isj ust rotary for you
the glowing exhuast can be from something plugging the system causing heat build up
running lean actually makes your exhuast temps hotter
and retarded timing will also make your exhuast run hotter
might want to check those out
Old Jun 16, 2004 | 11:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it can be brought out by severely retarted timing and a rich condition. i remember for a photo shoot at our local community college i retarted the timing 20 degrees on a SBC and jetted the holley up 4 sizes front and back to achieve that glowing headers look for an ad for school.
Old Jun 17, 2004 | 08:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
usually its from fuel burning in the exhaust... either because of timing, or because you're running rich.. or both.
thats also why when some people just slap a carb on a motor, time it by ear and drive, they burn the header paint off.
Old Jun 17, 2004 | 10:35 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Are you breaking in a motor or is this something that just started happening recently?
Old Jun 17, 2004 | 12:29 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
It's been doing it for a while now. I've been doing so much to the car over the last few years though so I'm not sure what I did or when exactly it started to do this.
Old Jun 17, 2004 | 04:36 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i've heard that when u put a new cam in it would do that for a little while
gta892000
Aug 11, 2019 11:16 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
