Mounting WBO2 sensor
Old Aug 23, 2004 | 04:56 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I did a few searches and didnt really find anything that say how far away or close to the head is acceptable. I have SLP 1 3/4" headers that are ceramic coated. I was hoping to just be able to use my stock O2 bung for temp/permanant use of the wide band, but I think this is a pipe dream. I have a LOT of tuning to do on my car and my exhaust is very hot i think because of the ceramic coating.
Basically how where should i mount the sensor? I am running a cat so I know it has to be before that.
Old Aug 23, 2004 | 05:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A wideband relies on its heater to maintain the correct operating temperature, so you can put it anywhere in the exhaust you want. The farther it is from the heads the longer it will take to respond, however. You could mount it permanently in the stock location (assuming you don't need to keep the stock O2 sensor for the ECM, of course), but never run the car without the sensor's heater working or you'll ruin the sensor in a fairly short period of time.
Old Aug 23, 2004 | 05:15 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I was under the impression too that the sensor could be too close to the head also even though it is heated. But how close is too close?
Yeah thanks for the tip on the sensor and running it heated all the time. I have read that several times.
Old Aug 23, 2004 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unless you're going to try to put it in a primary tube, I don't see how you could get it too close.
Old Aug 23, 2004 | 06:25 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
according to Zeitronixs' install instructions :
"Never mount the oxygen sensor in stock factory location or closer than 12" from the headers. Exposing the senor to the tempature above 800 C will cause sensor damage."
Old Aug 23, 2004 | 06:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
800 C is almost 1500 F
Old Aug 23, 2004 | 07:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Wait 12" from the headers? So it would have to be in the y pipe then. Are you saying that 1500 is a high temperature and that it shouldnt be too hot if I install it in the collector of the drivers side? The SLP location
Old Aug 23, 2004 | 07:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unless you're running pretty lean under load your exhaust shouldn't be getting quite that hot.
Old Aug 23, 2004 | 08:02 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
OK thanks
Wife'sCar
Sep 5, 2015 08:58 AM
Bert87
Aug 23, 2015 03:50 PM
timonator
Aug 11, 2015 09:56 PM
