hedman y-pipe problem
Old Oct 1, 2004 | 09:00 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
how tight do you tighten the y-pipe to the colectors? I think i messed up. one opening of the y-pipe is now warped along with one of the bolts. Now i have a fairly large exhaust leak. sugestions? tighten the the bolts more? use some copper exhaust rtv? this is bothering the hell out of me.
Old Oct 1, 2004 | 02:33 PM
IBTHA1's Avatar
Car: 89 GTA WS6
Engine: 5.7
Transmission: turbo 400 shift kit
Do you have "ball and socket style flange" on both the headers and y-pipe or are they both flat flange or is one ball and one flat??? This is a current problem with the new Hedman stuff. Figure this out then I can help u correct ur prob.
Thanx. JIMI Rep 4 ACS
Old Oct 2, 2004 | 06:07 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
If heddman is sending out headers with the flat 3-bolt style flanges, then what's the difference between them and the Hooker 2460's? If they're making the ypipe with the flat flanges, then you can use the heddman ypipe with the hooder 2460 headers
Anyway, mine came with the ball and socket flanges. If you don't have them lined up right before you tighten them, it will pull to one side and open it up. Loosen them all and re-align.
Old Oct 3, 2004 | 09:50 PM
nah.. i bought them months ago.. they are the ball style. the problem was the bolts that came w/ the headers were garbage and bent. I just got new bolts an tightened the crap out of them..... so now my car doesnt sound like a john deer anymore.:lala:
Old Oct 4, 2004 | 03:42 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I had a post on this last year when I couldn't get mine to connect up either. I ended up using a pair of exhaust doughnut to make up the gap and since they are soft lead, I think, they conformed around header and collector perfectly. This kept the exhaust from being drawn up tight against the oil pan and the crossmember. No leaks and they can be reused if you need to take the exhaust down as long as you don't destroy the doughnuts. I still have the part number of the doughnuts I used on my car if you need it.
Old Oct 9, 2004 | 12:24 AM
IBTHA1's Avatar
Car: 89 GTA WS6
Engine: 5.7
Just to correct a point ( as I sell the Hedmans) They still sell Flat flange, And Ball and socket style hdrs and y-pipes and as with any Co, they @(*&*$^&% up and mix them up more often than not.
Old Oct 11, 2004 | 12:09 PM
Engine: LB9/383
Then they need to get their **** straight and send out the right stuff.
Old Oct 11, 2004 | 09:49 PM
84350camaro's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
im pretty sure i have flat flanges on both y-pipe and headers....i got the headers liek in february from summit and the y-pipe in july or august from them too....so since both are flat am i gunna be ok with them?
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
