Exhaust and backpressure question?
Old Nov 16, 2004 | 09:28 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I have a pretty much stock 5.7 TBi with a high lift/duration cam. Edelbrock Headers with a y-pipe that narrows to 2 1/2 inches. 2-1/2 inch exhaust is what everyone recommends for the HP that i have. People are recommending that i stay with 2.5 " all the way out because they say if i go to 3 " the reduced backpressure will cause the computer to do screwy things with the idle mixture or something like that.
BUt everyone on here is saying anything less than 3" sux.
Anyway, Ive got this complete spintech 3" catback, I want to hurry up an get on the car, but i have this 2.5 " y pipe and stock cat.
Should i just cut the y -pipe at the reducer and get a cat with 3"in and out? and what about this backpressure deal?
Old Nov 16, 2004 | 02:43 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I'd say put it on. For now you can leave the cat the way it is. After you have more funds then I would recommend getting a 3 inch cat and getting rid of the reducer. At that point your system should flow pretty good. Remember that the less back pressure that you have, the better the car is going to run. Some poeple will tell you differently though. For more info, do a search for back pressure. This is definatly a subject that has been beat to death and then beat again. Also, since you have a bigger cam your getting more fuel and getting more air out so the more flow you have the better it will run.
Hope that helps.
Old Nov 16, 2004 | 06:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You would benifit from a 3" exhaust. Backpressure is bad and you never want it. People get this confused with scavaging. Chip work will make the most of every mod on a TBI set-up.
Old Nov 17, 2004 | 02:05 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Thanks guys, Then thats it The 3 inch spintech will be on by the weekend, if the cat gets here by then.....I can hardly wait. :lala:
Old Nov 21, 2004 | 05:42 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if your bored take a look some time
https://www.thirdgen.org/techbb2/sho...t=backpressure
has lots of interesting info, link, and other ppl chiming in
but good read none the less
993
Old Nov 24, 2004 | 03:20 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Wow...lol....Okay ive come to the conclusion that backpressure is bad anyway you look at it.
the fact of the matter is that going to a too large exhaust pipe actually can create more backpressure because of the eddies and swirling gas effect thing happening. Its so ez.
I think 3" is fine for my car. Oh and i went with a magnaflow cat.
Old Nov 24, 2004 | 04:25 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
No Muffler, no cat, and hardley any pipe. Exits right at the Y pipe. Noticed increased throttle response, and power all the way around. Did I do good? hehe
nidyanazo's Avatar
Old Nov 24, 2004 | 09:43 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I hope you keep your windows open a crack all the time.
Old Nov 25, 2004 | 01:37 AM
nidyanazo's Avatar
usualy all the way down. stupid poison gasses.
nidyanazo's Avatar
not much back pressure though!
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
