Hedman y-pipe says 3in??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys, From everything I have read on here it says that the y-pipe for the hedman headers (17470) is 2.25in into a 2.5in pipe, But on the Summit wesite it says its 3in. Anybody know whats up here?? If its two 2.5in pipes into a 2.5in pipe I'm buying it and weldin on some 3in... thanks
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
the hedman y-pipe i got from jegs was a 2.5, but it didnt say what size it was on the page where its listed. maybe they have a 3in y-pipe too, im not quite sure. you might want to call and double check..
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mine was 2.5".... i cut it off right in the middle of the 'Y', where it is 3".
Thats what mine looked like when I got it.
This is what I did to mine though, to get a 3" outlet... see the red line? Cut it off here.
Transmission: 4L80E/4L80E
The illustration would indicate a dual cat system.
http://www.hedman.com/pages/y-pipes.html That's the picture that matches the description I've always heard - the "3-inch outlet" is really an adapter that allows the pipe to slip-fit to a 3" cat.
I wouldn't take Summit descriptions or pictures to the bank.
Car: 89 Formula
Engine: Carbed 5.7
Ok i Have a better undersatnding but I am still lost on if the 2 pipes coming off the headers are 2 1/2 or 2 1/4, Is there any 2 1/4 on the y-pipe at all??
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
As it comes the two header pipes merge to a 2.5" pipe at the y. The 2.5" section is 16-18" long, then is adapts to 3".
My new y-pipe is now 3" the entire length, along with the rest of the system. I'm going to have a Bullet, exit out the passenger side in front of the tire.
It would be cool to add a venturi at that point where the header pipes merge!
