Any way to kill the *snap*?
Old Apr 10, 2005 | 12:13 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Hi everyone.
Just finished installing new exhaust. I put on dual 2.5 inch pipes with magnaflow mufflers. At an idle it sounds really nice. Nice deep tone. But as soon as you hit the throttle, or put the engine under any kind of load it snaps retardedly loud. Is there anything I can do to try and kill the snap?
-HD
Old Apr 10, 2005 | 12:25 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Not sure what you mean buy snap but with my duals its quiet but under any load it gets loud and insane loud at WOT. Do you mean a actual snap noise like when you snap a twig?
Old Apr 10, 2005 | 12:31 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
More like snapping a whip...
Old Apr 10, 2005 | 12:47 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
When you let off the throttle? Or apply it?
Old Apr 10, 2005 | 01:44 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Apply it. No snap when I let off.
Old Apr 10, 2005 | 03:40 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Sounds like a engine issue to me more then your exhaust
Old Apr 10, 2005 | 10:05 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
nah, it's not an engine issue. It started happening right after I changed the exhaust. I don't see how that could cause an engine issue. If I can, I'll try and get an audio clip of it somehow. Any other ideas?
-HD
Old Apr 10, 2005 | 12:31 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Maybe your exhaust manifold Gaskets went. On my car they some how blew out a chunk and it sounded like a stupid safari with an exhaust leak. It happened when I changed my exhaust to. I guess because I was refing on the thing to get it of,f and it loosened the header bolts just a little bit.
Old Apr 10, 2005 | 01:17 PM
sp63
Guest
Posts: n/a
id say your snap is DEFINATLY an exhuast leak. i know this "snap" sound you are referring to and on my car it is an exhuast leak.
Old Apr 10, 2005 | 02:23 PM
klumb15's Avatar
yup sounds like an exhaust leak to me....it sound relatively small too, because when you get on the gas, it builds up a bunch of pressure then blows out, and if it SNAPS real loud it probably is someplace where you have a gasket...the gasket allows it to snap like a wet towel or something...
Old Apr 10, 2005 | 05:04 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Believe me...I've had the exhaust leaks that you're describing many times and I have a keen ear for picking up on it. This is total exhaust. I'll record a clip of it somehow and then maybe you'll understand what I'm talking about. I'm sure it'll help a lot.
-HD
Old Apr 10, 2005 | 05:24 PM
klumb15's Avatar
maybe you got a bad muffler...like one of the baffles didn't get welded or something...
TMZIrocZ350
Oct 7, 2015 12:09 PM
FormulasOnly
Oct 2, 2015 05:52 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
DARKmj16
Sep 9, 2015 04:07 PM
Jlanz55
Sep 6, 2015 07:28 PM
