Which is quieter?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Which is quieter?
On a single 3" in/out setup.Which will be quieter?I know the flow ratings..just worried about sound level!
Dynomax Ultra Flow welded #17233 with a 20" case length (Glass-wrap perforated tube)
or
Hooker Areo Chamber #21505 with a 14" case length (Chambered)
Case length says Dynomax to me..but...any real world experiences?
or
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Check my sig, for a dynomax ultra flo, i think its 17220 not sure right off, 3 inch center in and out, its the 14 inch case tho.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Which is quieter?
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
https://www.thirdgen.org/techbb2/sho...hreadid=318789
go there for hooker
quiet at idle, but good and loud at WOT
go there for hooker
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Re: Re: Which is quieter?
Originally posted by ShiftyCapone
If you are looking at their bullet muffler than the Dynomax will be tremendously louder than the aerochamber.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive had every muffler made on my car and the dynomax stil rocks!
the oval dynomax will take care of you.
the hooker is just a tad louder, IMO, but either is a good choice.
the dynomax will have less interior noise.
the bigger it is, the more noise its gonna eat up.
go as big as will fit your application.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
That's my plan..bigger is quieter.But it seems to be near a 50/50 split for either muffler.I am leaning towards the Dynomax.
On another note...do you have any pics of you current motor setup?I am looking into a carb LS1 swap.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
there is a pic of the engine in that thread.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Any other recommendations on which one to go with that will be quieter?
Seems to be a 50/50 split.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i just took off a single in and out dynomax 3" for the single in dual out 3".
the dual out has a lil less noise under acceleration, WOT, and at idle.
lil more raspy when you let off the gas from acceleration.
i give the dual out thumbs up over the single out, tho it doesnt flow the cfm the single out does, i doubt its hurting any power.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Back from the dead...
So I finally swapped and went with the Hooker Areo Chamber #21512 with a 22" case length (Chambered). Nice rumble at idle, absolutely no more "tinniness" to the sound and overall just sounds more "muscle" even for a single 3". I have mp3's of before and after, but how do I post them here?
