Gotta run my duals over my axle, what pipe to use?
Old Oct 10, 2005 | 03:10 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Any who ran their duals over the rear axle: where did you get the piping from? I ran 2.5" dual exhaust and the mufflers keep hitting the ground, so I'm looking to relocate them in the rear area rather than dumping before the axle.
Old Oct 10, 2005 | 05:07 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
www.jcwhitney.com
Old Oct 11, 2005 | 04:16 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
You want Stainless or aluminized???
www.stainlessworks.net
www.summitracing.com
Old Oct 11, 2005 | 04:44 PM
Car: 86 T/A
Engine: HSR 355
Thanks deadbird.
To anyone else posting or will post, I know where to get piping. I'm looking for specific model numbers of what they used to get over the axle. I can get alot of angles and weld them together, but I'm sure someone found a place with the pipe thats just the right size that it fits well and is cheap. Also, the pipe is 2.5".
Old Oct 11, 2005 | 06:29 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
The only way you will accomplish that is to buy two of the correct camaro/firebird exhaust pipes, cut the over axle portion out of them and use that. Ain't going to be cheap though. Similiar to that "$1000.00 ebay 3" exhaust" evryones talking about.
Old Oct 11, 2005 | 11:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
Originally posted by firebirdjosh
[B]Thanks deadbird.
N/p.. I thought you were looking for pipe to fab instead of pre-fab pipe to mod/use for your setup.
Old Oct 15, 2005 | 03:07 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I used 2 Dynomax 2 1/2" Pipes.
Old Oct 15, 2005 | 04:20 PM
Rob Wade's Avatar
Exactly what I meant ,Z. Nice work.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
red90IROCls1
Aug 25, 2015 06:56 AM
