Edelbrock Headers
Old Oct 17, 2005 | 09:03 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
Edelbrock Headers
I haven't read anything good about edelbrock headers, but found some for a good price, just tryin to see if anyone who has or does own them has had any good experiances with them. Summit Part # EDL-68723
Thanks,
Trey
Old Oct 17, 2005 | 09:29 PM
EvilCartman's Avatar
Car: '82 Z28
I went 12.22 @ 111 mph with a set of Edelbrock shorties on. Yeah their y-pipe sucks (or the one I had did) but they're better than running manifolds. Never had any problems with them myself.
Old Oct 18, 2005 | 12:41 PM
DTM 91 Z28's Avatar
Car: Camaro
very good headers for the money. provides a noticeable power increase... a little hard to install on the passenger side though. Ti tech coating does its job on the headers, but slight surface rust will form on the y pipe
they are good headers for a first timer because you wont notice the scratches you will get on them while installing. 3rd spark plug from the front on the drivers side will be impossible to remove unless you modify a spark plug socket. put in the spark plugs before you bolt on the headers.
Old Oct 19, 2005 | 10:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
They are a VERY big improvement over the cast iron manifolds GM blessed your car with... just by comparison to other headers, like Hedman, Hooker, SLP, etc, they aren't as good.
Old Oct 22, 2005 | 07:52 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
And use Accel shortie plugs if you plan to replace plugs ever again!
Old Oct 23, 2005 | 08:49 PM
DTM 91 Z28's Avatar
Car: Camaro
do you have edelbrock headers and accel plugs? Can you remove the spark plugs easily with a standard spark plug socket?
Old Oct 24, 2005 | 10:14 AM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i was also looking at edelbrocks. ive heard great things about the hooker y -pipe. is it possible to use a hooker y pipe with edelbrock headers?
Old Oct 24, 2005 | 11:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by MaNiAk86
... is it possible to use a hooker y pipe with edelbrock headers?
Not without modification. Modifying the Edelbrock y-pipe would be easier.
Old Oct 24, 2005 | 08:19 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
I had my old plugs on at first but after trying to use a plug socket on them I replaced them with the Accels before buttoning everything up. I couldn't use the socket on 3 of the standard-lenghth plugs.
Old Oct 24, 2005 | 08:39 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I just installed the edelbrock ceramic coated headers this summer I got from summit racing. The install wasn't bad. The thing I liked about them was that everthing came with them. I didn't have to go out and buy anything else to install them. I also use the stock spark plugs with them. Changing the spark plugs really isn't any harder than it was with the stock manifolds. I did have to use the spark plug socket and a wrench on a couple, but atleast I don't have to get under the car anymore to change them.
Old Oct 25, 2005 | 03:49 PM
91bluemetalicRS's Avatar
I had the edlebrock shorties big improvement over stock but the y pipe is terrible. had to have an exhaust shop chop it up and reweld it to fit around oilpan. A month or two ago the collector welds cracked on the inside of the collector. I bought some headman full lengths and could not be happier. If your putting headers on a blown 350 I would think your best bet is the full length hooker or headmans.
Old Oct 25, 2005 | 06:49 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
They must have changed the design since last summer because I couldn't get a socket on the #1, 3 or 8 plug at all, using AC Rapidfires...
Old Oct 28, 2005 | 12:49 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Good post here on the TES. Have mine on the 88 for six months now, well satisfied so far.
https://www.thirdgen.org/techbb2/sho...hreadid=283511
Hotrodboba400
Dec 10, 2019 07:07 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
