Thicker Flanges?
Old Nov 6, 2005 | 04:43 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Thicker Flanges?
Has anybody here gotten a set of headers and modified the flanges? what i mean is make the flanges thicker by welding on more steel. I know it sounds like a dumb question but i'm just curious, because i `ve known some header flanges to be quite thin.can it be done?
Old Nov 7, 2005 | 12:16 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If you just buy the better headers, the ones that don't cost $100. They will thicker flages, thicker tubes and be of better quality. It would be way to much work to make thicker flanges and would cause lots of problems. Its just not a good idea. Now you could buy some thick flanges and make your own headers.
Old Nov 17, 2005 | 07:25 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
So true! You get what you pay for!
Old Nov 19, 2005 | 07:22 PM
I don`t mean buying cheap headers and modifying them.I mean if I bought some 2055's or some hedmans and made the flanges thicker, to almost act like a spacer to clear the plugs better.I know many have thought that the 2055's flanges could be a little thicker.thats what I meant.
Old Nov 19, 2005 | 07:24 PM
Rob Wade's Avatar
You might run into frame clearance issues by pushing the primaries out to far.
Old Nov 19, 2005 | 07:39 PM
would 3/4 of an inch be to far you think?
Old Nov 19, 2005 | 08:20 PM
Rob Wade's Avatar
Wow! Thats alot of steel. Why do you think you need that much material? Most header flanges are 3/8" thick, some 1/2" but 3/4" inch is huge. Are you talking 3/4" total flange thickness or 3/4" on top of the origional flange? Its been a while since I looked at an fbody header for clearance, but I gotta think that moving the header that far out is going to hit something.
Old Nov 19, 2005 | 09:11 PM
I mean 3/4 inch total thickness of the flange.
Old Nov 19, 2005 | 09:53 PM
Rob Wade's Avatar
I think its a little overkill and could cause clearance problems. All you can really do is measure it in the car.
Old Nov 19, 2005 | 10:01 PM
I don`t think I`d have many clearance issues due to the fact that I`ve ripped most of the usual obstructions out of the car.(see pic)
maybe on the drivers side but deffinitely not on the passenger side.
Old Nov 24, 2005 | 12:36 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
its atually on the passenger side that i've has all the trouble with mine. I have a set of Hooker 2460's and they didnt wanna go in that side at all. i remember hearing somewhere that the engine is mounted slightly to the passenger side to compensate for driver weight in these cars.
Rousseau92maro
Feb 1, 2016 05:12 PM
no green
Jan 9, 2016 09:22 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Eric-86sc
Sep 22, 2015 08:25 PM
