Bending pipe for exhaust
Old May 12, 2006 | 10:37 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I was thinking about buying a pipe bender to try to make my own bends but was wondering if anyone knows anything about it. Can i use this style bender on exhaust pipe? http://cgi.ebay.com/NEW-16-TON-PIPE-...QQcmdZViewItem
Old May 12, 2006 | 10:39 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
i think u can.
Old May 12, 2006 | 10:41 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
heres a pic incase the sale gets deleted
Old May 12, 2006 | 10:42 PM
Car: 84' Trans Am
looks good, how much $$$ is it goin to run
Old May 12, 2006 | 11:23 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Cheap. 180 shipped, but im not sure if its going to cut it. exhaust pipe is pretty thin stuff it might just crease it.
Old May 12, 2006 | 11:24 PM
Car: 84' Trans Am
what r u planning to bend with it?
Old May 12, 2006 | 11:28 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
3'' exhaust piping if it will work.
Old May 12, 2006 | 11:33 PM
Car: 84' Trans Am
custom exhaust?
Old May 12, 2006 | 11:47 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
going to try to make custom exhaust yes. If this will bend the pipe im going to fab up several kits for our cars and expiriment with them as far as performance and sounds quality. I have a friend who can weld exhaust like a dream so this hopefully will work out.
Old May 13, 2006 | 01:14 AM
slick88gta's Avatar
Car: 88 GTA
Engine: 350 L98
Axle/Gears: 3.45 9 bolt posi
That will just kink and or crush it, its too thin wall of stuff to use that and it turn out good. Thats more for rollcages and such. Mandrel exhaust benders are a couple grand I think, if they were just 200 bucks alot of people would have em....
Old May 13, 2006 | 10:17 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
If you welded the ends of the pipe shut and filled it with sand that bender would work.
Kory
Old May 13, 2006 | 03:59 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
That will work if you want crushed bent pipes...mandrel bent pipes are expensive because the equipment is a fortune....a mandrel bender is tens of thousands of dollars. I've seen 3" units starting at around $35K+.
- Joel
Old May 13, 2006 | 05:09 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Ditto, you'll need something like this
eBay Motors: HUTH EXHAUST PIPE BENDER WITH 3 INCH DIES MUST SEE !!!! (item 4639341843 end time May-16-06 20:03:26 PDT)
I have some friends that have one. They found an exhaust shop several years ago that was going out of business and picked up the bender along with all the dies for $1k. But, you will only find a deal like that if you're lucky. Look at spending big $$$ for a machine to properly do customer exhaust.
Old May 13, 2006 | 06:01 PM
Engine: 6.3L - 383
That bender is a nce unit...Huth has been around a long time...they make good equipment....everything from entry level to pro. That unit will not mandrel bend though.
ccop
Convertibles
Sep 14, 2015 04:13 PM
bamaboy0323
Sep 12, 2015 07:14 PM
iroczz89
Sep 12, 2015 04:55 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
