The Final Answer on True Duals(with pics)
Old Jun 5, 2006 | 08:39 PM
Shagwell's Avatar
Car: projects.......
I've been asked countless times now, and I've needed to post it...
My Exhaust
Headman LT's
Headman universal 2-1/2" x-pipe
Hooker Maxflow mufflers
I've said it before and I'll say it again. It's not worth it. There's no power gains to be had over the LT's, a good y-pipe, and a good single system. There's only the sound and the wow factor. My system tucks completely up under the car, out of site, and off the pavement. It takes a lot of frame modification. I was doing the LT's and homemade sfc's at the same time and things kinda got outta hand with the smoke wrench.
- Now the pics. Some of these were taken as I built the system, some have been taken now, with everything partially dissassembled(re-doing the car) I can't seem to find any shots with the mufflers in place, so the x hangs a ways toward the back, as the trans x-member is the only thing holding it up.
Attached Thumbnails The Final Answer on True Duals(with pics)-suspension-032.jpg   The Final Answer on True Duals(with pics)-suspension-018.jpg   The Final Answer on True Duals(with pics)-suspension-016.jpg
Old Jun 5, 2006 | 08:42 PM
Shagwell's Avatar
more....
Attached Thumbnails The Final Answer on True Duals(with pics)-suspension-015.jpg   The Final Answer on True Duals(with pics)-suspension-014.jpg   The Final Answer on True Duals(with pics)-suspension-013.jpg
Old Jun 5, 2006 | 08:46 PM
Shagwell's Avatar
frame mods/sfc's...
Attached Thumbnails The Final Answer on True Duals(with pics)-suspension-020.jpg   The Final Answer on True Duals(with pics)-suspension-021.jpg   The Final Answer on True Duals(with pics)-suspension-027.jpg
Old Jun 5, 2006 | 08:51 PM
Shagwell's Avatar
more....(sorry mods, hope I'm not going overboard, just been asked many times)
Attached Thumbnails The Final Answer on True Duals(with pics)-suspension-029.jpg   The Final Answer on True Duals(with pics)-suspension-028.jpg   The Final Answer on True Duals(with pics)-suspension-025.jpg
Old Jun 5, 2006 | 08:53 PM
Shagwell's Avatar
final two...
Attached Thumbnails The Final Answer on True Duals(with pics)-suspension-030.jpg   The Final Answer on True Duals(with pics)-suspension-031.jpg
Old Jun 5, 2006 | 09:07 PM
Shagwell's Avatar
I know the pics aren't the greatest, but I have a single car garage and a floor jack. - I have no lift, and the car is down(getting completely gutted floors, firewall, and all unibody crap included) All welding on this car was done with a stick welder(Lincoln Ranger 8 gas-powered)
The factory front sub-frame was cut out from the firewall back. I used 2x2 box tubing welded to/through the floor full length. The box actually slides into the rear frame, then back into the front(to the outer edge) and was plug welded. They are also tied to the factory vert rocker box braces and tied to my roll cage. I then took two pieces of 1/4 thick 2" angle and welded them from the inside edge of the front subframe to the box tubing. This allows the header pipe to come directly off the headers, no drop down/twist around. I have no rear-seats, so I cut the humps out of the floor and put flat panels back in place, which allows for placement of the mufflers. I could have run tail pipes but never did, I simply had two short pieces of pipe coming out the back of the mufflers, stopping just forward of the axle tubes.
The two pieces of angle have a welded 3/8 nut on the top side of each(untouchable after install) for my trans crossmember bolts.
Also the pipe you see at the top of the last two pics is my tq arm/ds loop crossmember. It sits just tailhousing of the trans.
Old Jun 10, 2006 | 10:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I wish I could do my own dual setup. Nice job!
Old Jul 20, 2006 | 04:22 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
thanks for the information
Old Jul 23, 2006 | 10:29 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you cut the unibody subframe?
what type of metal did you use to replace it?
looks unsafe to be honest.
Old Jul 23, 2006 | 11:01 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
May I ask what data you have to conclude that there are no power gains to be had and that it is not worth it?
Curious to know what power level you are at and how you made this determination.
Thanks,
-Schultzy
Old Jul 23, 2006 | 11:45 AM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
very nice work...major props
Old Jul 23, 2006 | 12:21 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Old Jul 23, 2006 | 12:32 PM
Rottluver's Avatar
Car: 07 Trailblazer SS
Engine: 6.0 LS2
Transmission: 4spd auto
Axle/Gears: AWD w/4.10's
Thanks,
-Schultzy
I dunno about anyone else, but when I went from just a catback and bolt ons to long tubes and true duals (3" mandrel bent all the way over the axle with x-pipe, dual 3" cats and 18" magnaflow 3" diameter bullet mufflers) I actually did not gain one single hp or ft/lb of torque. Granted I was not using the same dyno as before but the numbers were identical!!!!! It was kinda weird. I picked up a little at the track but unless you have a stroker motor (more cubes) or are using forced induction, or some pretty healthy heads & a wild cam, true dual exhaust won't provide a HUGE increase in power generally speaking. Obviously every car/person is different but you have to have the other parts be able to move large volumes of air before you will really sdee too much diff with true duals. They sound nice and look cool and it is cool to say I have em, but they didn't do a lot for me performance-wise. 2-3 tenths at the track tops. :shrug:
Granted this is on a 4th Gen LS1 but the concept is the same on any motor......if you don't have the equipment to move the air at a much higher rate, having that bitchin hi flowing exhaust won't be as big a help as a person might think.
Just my $.02
Old Jul 23, 2006 | 12:41 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
dude, that is a HUGE gain.
Old Jul 23, 2006 | 12:49 PM
Rottluver's Avatar
Engine: 6.0 LS2
:sorry:
I expected a lot more going from factory manifolds, y-pipe and catback to long tube (QTP) headers with full 3" dual exhaust............that 2-3 1/10's was also at a track with a MUCH lower DA then then one I normally used.........not saying I dislike the gain, just that I guess I thought it would be more significant.
Old Jul 23, 2006 | 12:52 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
:sorry:
depends on the HP level. your manifolds might have been doing a pretty good job, even a hundreth is a huge gain. always fun to go faster.
Old Jul 23, 2006 | 01:18 PM
Car: 1989 GTA
Exactly. So what were your dyno runs and what were your 1/4 times. Just trying to qualify this with some objective data. Thanks.
-Schultzy
Old Jul 23, 2006 | 04:49 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I was thinking about making street legal true duals just for the wow factor
Old Jul 24, 2006 | 11:02 AM
Rottluver's Avatar
Engine: 6.0 LS2
-Schultzy
Well that would be the first time I ever heard of LS1 F-Body manifolds (and the adjoining 30+ lb each - <no joke> catalytic converters) doing a good job compared to top of the line long tube headers, but I suppose anything is possible.
With factory manifolds, the normal LS1 bolt ons and an SLP Loud Mouth catback I got 357 rwhp and 367 rwtq. On the same brand (different location) dyno a couple months later I got 357 rwhp and 367 rwtq after installing QTP long tubes and the full on 3" mandrel bent true duals........including "high-flow" cats, 18" bullet mufflers, etc. (it was kinda spooky that they were IDENTICAL #'s) Temp, humidity, etc were pretty much the same both dyno days. For the (almost) 2 grand I spent in headers, exhaust, etc I was hoping for more then 2/10's & ZERO hp or tq. Not the end of the world, just little bit of a downer. Yes, going faster is fun but I had slightly higher expectations. Cest la vie.
My 1/4 times (and yes, I am a sucky driver) went from 13.6 @106 (before) to 13.4 @ 108. And again, those first time #'s (which were pretty consistent the 5-6 times I ran at that track) were at LACR in Cali, high elevation, even higher DA. The "faster" times (ran 3 times and they were all pretty much the same) were at Pacific Raceways near Seattle.....MUCH lower elevation and DA!! And yes, yes, yes, I know my times suck. It is a 6-spd with a weak-*** 10 bolt and I am a sucky driver. Oh well, life isn't over, just bummed me out. I am sure with a better driver and an automatic, my car would be significantly faster.
Old Jul 24, 2006 | 11:08 AM
Rottluver's Avatar
Engine: 6.0 LS2
That is exactly why I did it, along with the delusion that I would get some good power out of it.
If you can get it done where they don't scrape or hang so low that shadows get stuck under them, I say go for it if you want to. Only reason I am bitching is cuz the place that did mine did a crap job running the pipes and so now, 2 years later, I am paying the price......I am actually going back to a catted Y-pipe and catback at the first of the month. Found em both brand new for a total cost of a good catback and that was about 1/3 the price that the best shop up here (not the same place that did my duals) quoted me for "fixing" my TD's to make them suck less.
Old Jul 24, 2006 | 01:11 PM
TJs57TPi's Avatar
so who makes a y pipe for long tubes for the third gens? besides the 4 inch mufflex one that is ridiculously priced
Old Jul 24, 2006 | 09:56 PM
Stang Stomper's Avatar
Car: 86 z28
Transmission: six speed
Axle/Gears: Ls-1 342's
New here and don't want to make anybody mad but I have true duals on my car with out any frame mods. The mufflers are a little low in the back but no real drining problems. I dont now about the power gains but it sounds good.
Old Jul 26, 2006 | 09:23 AM
383firebird84's Avatar
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
i got true duals on my car the sound is just so much better then my old 3 inch single and i picked up 4 tenths on my 1/4 times with using the same haeders as i had on there just added some s extensions an x pipe and spintech pro shootouts and dumped it
Old Jul 26, 2006 | 10:16 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
true duals are simple
long tube headers
and summit s-curve collectors
straight pipes on them, and a coupel cheap turbo mufflers at local auto parts store, about 22 bucks each
not full length, but its cheap and simple and easy
good luck
Old Nov 3, 2006 | 02:18 PM
Shagwell's Avatar
- It's been a while since I checked back, I don't "cruise" the exhaust board, mostly suspension and the drivetrain board. -
I gained nothing in the 1/4 when I switched from headman Lt's with a 3" cat-back to the 2-1/2 duals. Same 60ft's, same 330, 1/8th, etc. The car sounded very different, but my numbers remained the same, conditions within a few degrees and the same humidity at the track. I did gain some switching from shorty headers/y-pipe to the Lt's though.
I cut part of the factory subframe out because with 2x2 box welded full length through the floor(above the rear foot well, as they run straight through the car), slid into the subframes at each end, the tapered in part of the front subframe meant nothing in terms of strength. Even before I put the cage in I had very limited twist in the car with my "frame rails" installed.
I went for perfection, not cheap. I wanted zero clearance or any other issues commonly associated with routing duals under our cars. I hate being able to see someone's exhaust hanging down under the car, IMO, it just looks tacky and kills the lines of a car.
Old Nov 5, 2006 | 01:28 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
if you had to cut the subframe you did it wrong...
Headman 1 5/8" longtubes from a 2nd gen Camaro, 2.25" pipe, H and flowdisasters. Engine made 300 HP and 400 TQ on bone stock 882 truck heads, 9:1 compression, .495/.502 cam, single plane intake and a 750 carb.
I did notch my subframe about 1/2" to get rid of some rattle... but it got welded back together with 1/8" plate. i've put about 1,000 miles on it and only scraped once. I also put normal sized front wheels on it so ground clearance got better...
Old Nov 7, 2006 | 01:16 PM
Shagwell's Avatar
Yes, it can be done differently than I did it. Your's is fine, looks good. As I stated, the reason I did mine this way was because I wanted ZERO loss of ground clearance, and I wanted it fully tucked up under the car so it couldn't be seen. Your collectors hang about 2-3" lower than mine do. The headmans' dump just below the floorpan, right at the subframe. I wanted straight back, no s-bends/etc to offset down. If it hung down any, daily driven with sportline springs would bounce it off of speed bumps, pot-holes, etc, which is why I didn't do it that way. Plus, it's completely out of site, as the factory vert rocker boxes are lower than the exhaust.
Old Aug 19, 2007 | 06:40 PM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Re: The Final Answer on True Duals(with pics)
.3 tenths is still about 30 hp though, I'm going to have my true duals done soon, I never had headers on this car at all or exhaust, so no loss.
It will be ceramic coated 2210's, with 2.5" duals, into a h-pipe, I'll do a x-pipe, when I'm going to 3" duals when it's over 550 hp, then bullet mufflers, and dumps before the rear wheels. I'll post some pics of it, when it's done.
Old Aug 19, 2007 | 07:34 PM
Rottluver's Avatar
Engine: 6.0 LS2
Sounds like a good setup. Looking forward to the pics.
Old Aug 19, 2007 | 08:06 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Shagwell,
I know that your was done to be able to build true dual exhaust and I am not trying to thread jack you. I had not seen anyone else remove the factory sub-frame like I did. I now see that you have also done it. Nice job.
I am going to post a link to my cars exhaust. I built a single 4" system not true dual but the frame concept is the same. I just figured that some of the people here might care to see another way to gain room for exhaust.
https://www.thirdgen.org/forums/exha...t-picture.html
I spent a bit more time removing my sub-frame and fabricating new frame rails. I do not have pictures of the SFC installed in this thread but the concepts were exactly the same.
Nice job.
Old Aug 19, 2007 | 08:16 PM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
Sumthing i worry about running pipes so close to the transmisson is heat the cooler the trans run the better we all are sure to know, so a heat sheild and after market large trans cooler should be kept in mind...
unless you have a few trans laying around. :0)
I do have a question tho what's the benifit of have the X so close to the headers as to crossing them lets say, for shoots and giggles, near the drive shaft? I did that on a truck i had and still had gain in low ends and real mellow sounds.
Old Aug 19, 2007 | 08:34 PM
Well, I'm not doing the x-pipe setup for a while, I'm just doing a h-pipe first. Scott Parkhurst, told me from Popular Hot Rodding, that X or H pipes are the most affective within a foot after the collectors. Y's are affective a little further from the collector. I am sure if that he will put enough room in between the y-pipe and the trans. Plus, the heat coming off the y going into the trans is not that hot, that it would damage the transmission, it's the cooler that does it's job, if he feels the heat after it's warmed up, he'll do what's needed.
Say he puts a piece of sheet metal on top of the y, that will prevent most of the heat from going right up onto the transmissions pan. And at least when your driving, most of the heat will go back.
Old Aug 20, 2007 | 01:02 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
no matter what exhaust you run, its going to get close to the tranny. i dont see any issue at all.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
