A/C bracket for shorty headers, 91 Camaro
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I am getting vibration because of that lack of a rear bracket on my A/C. I have a 91 camaro with hedman shorties on it. Any companies make a bracket I can use?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you still have the original bracket and it's the same as mine-attaches to the block at the first and second manifold bolts then to the power steering pump and compressor. Try trimming off the rear half of the "U" (that attaches to the second exhaust manifold bolt). You can then attach the bracket to a stud at the front of the manifold (or hedder), the power steering pump and the compressor. Worked for me several years running.
Engine: L03, LS1
Im on the passenger side not driver side with the power steering. The original bracket went to the cast manifold.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
The original bolt is what you will need to use, unfortunately. I've had mine on for years and have never had a problem with it.
Car: 92 Z-28
Transmission: THM700R4
I'm a newbie to the exact car that you have, only a '92. I am about to purchase Hedman shorties. Do you know if that is one of the problems with Hedman shorties, that the A/C bracket needs to be altered? Sure would like to know.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres what you'll need to do:
goto the hardware store and get a stud that matches the current header bolt.. get three nuts and washers to match it.
remove the header bolt where it used to bolt to.
screw in the stud.
put on one washer and a nut.. tighten the header.
put on another nut partway down the stud, then the washer, then the brace/bracket... then another washer and the last nut.
adjust the nuts until the bracket/brace is in the correct position.. then hold one nut still with a wrench and tighten the other.
i did a howto with pics on this years ago... it should be on here if you search with my name.
screw in the stud.
Engine: L03, LS1
See I don't want to do anything like that. I wan't it to be made to work not me make it work. Theres gotta be a company out there like march that makes a complete setup.
Car: 1991 Z-28
Oh, there is. You can get the setup from March or I think it's called Vintage Air. Their system doesn't use the brackets like the factory setup. Downside, you have to fork out $$$ for the complete setup.
Engine: L03, LS1
Yes I don't want to throw down a craplod of money for a bracket. Theres gonna be something. Any reason why the older syled brackes wont work?
You've got serp set up right? Older style, like mine, use a v-belt set up. I'd recommend taking Mr. Dude,s advice. It can be done easily, at little cost and you can use stainless pieces that will look sharp.
Engine: L03, LS1
Ok where can I get the factory brackets then. This is really retarded tho that nobody makes one.
Which bracket are you looking for? Do you need to replace your original bracket? If there's not a JY near you with these pieces, try Hawk's. If they can't help you let me know as I'm hitting my local guy tomorrow afternoon (if work lets me out early).
Car: 91 Camaro Vert
no.
its really retarded that you expect a perfect OEM fit with an aftermarket header.. and that a clean, workable solution is availible for cheap, and you want to buy something totally diffrent because of it.
i guess i could make you a billet stud and have it all shiny.. nothing sticks out like a sore thumb and grabs your attention like a piece of billet crap on an otherwise stock motor.
heres a tip.. since its already vibrating, id bet the bolts holding the rest of the bracket on, espically the ones down near the bottom of the block, are also coming loose now... snug them all up, then either use the factory brace, the factory way, with a stud... or use a single long bolt and a spacer... or jsut deal with it... if you choose the last option, i reccomend going back to manifolds.
With serp to v-belt, I was more worried about the water pump... and don't pick on me cause I like stainless, it's next to a coated hedder anyway.
Engine: L03, LS1
No it is retarded that they make it for older cars but not for ours.
Hedman Auto Air Conditioning Brackets: HED-20110 - summitracing.com
I am not looking for some fancy billet peice or anything. I am just not rigging a bunch of washers and crap in there. If your not gonna be helpful why even say anything?
Car: 91 Camaro Vert
i prefer to use washers so i dont gall anything... but i suppose you could grab some of thoes nuts with flanges on them so you dont need washers.
its a straight bolt. the only way you could make it more custom is if you omitted the threads partway up it and put a flange in the middle..
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
db057
Aug 11, 2015 10:11 PM
