t5/longtubes
Old Jul 3, 2006 | 10:07 PM
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
t5/longtubes
i currently have hedman longtube headers and im fixing to convert my car from a 700r4 to a manual 5speed. Will the longtubes interefere with the 5 speed or will they work? If it willl work, does anybody have any pictures of an exhaust system with longtubes and a t5. btw i searched and came up with nothin. thanx
Old Jul 3, 2006 | 10:17 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
This will happen.
The fix
All found with search. Learn to use it properly. It is a wonderful tool.
Old Jul 3, 2006 | 10:33 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
or hooker longtubes clear
Old Jul 3, 2006 | 11:37 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
you got to go with the hooker lt's. i had no fitment issues with mine
Old Jul 4, 2006 | 01:10 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Hookers would be better, buy they also cost a lot more. A hammer will save you some money if the engine isnt built to need 1.75" primaries
Old Jul 4, 2006 | 11:35 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
Hopefully you only have to dent them a little, for some reason I had to dent mine a lot, and I ended up throwing them in the garbage. That's if you decide to go with the hedmans. I also had to dent one primary. Hedman is $hit
Old Jul 24, 2007 | 10:41 AM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Re: t5/longtubes
Iknow this is an old post but what hooker lnogtubes are the ones that clear and what y-pipe can i use?Thanks
Old Jul 25, 2007 | 10:56 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: t5/longtubes
The Hooker P/N is 2210. Dont know about a y-pipe-----seems like i read that the mufflex y works on them. Also Doug's headers claim to fit the 5-speed and are less expensive than Hooker Jegs has them the ceramic coated are $535
http://www.jegs.com/webapp/wcs/store...0002_528847_-1
also available in non-coated
http://www.jegs.com/webapp/wcs/store...0002_528848_-1
Old Jul 25, 2007 | 10:08 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: t5/longtubes
i have a tko 500 trans and went a different route with the driverside header
i cut the collector off and welded an extension of 6 inches onto the header then welded the collector back on and made a slope that drops down 1 inch on top of the tube where the bracket for the clutch slave is its about 4 inches across.kinda like a recess in the pipe and welded peices to clear it and have a mint seal
Attached Thumbnails t5/longtubes-my-exhaust.jpg
Old Jul 25, 2007 | 10:19 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: t5/longtubes
Badass, not to hijack the post but I'm in CT now and I see your in MA. How the hell are you planning on emissions with duals?? Where'd you tuck the cats?
Old Jul 25, 2007 | 10:37 PM
Re: t5/longtubes
when i do need them they are further back about 6-12 inches from where that pic leaves off,i run the round cats so its easier to fit em in tight spaces
other than that i dont run em
Old Jul 26, 2007 | 08:25 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Re: t5/longtubes
i have the hedman longtubes and a tremec and lakewood bellhousing. the headers stock will not work, i had a guy add an extension in the tubes which dropped it down enough to clear a lakewood bellhousing.
Old Jul 27, 2007 | 06:36 AM
AC's Avatar
AC
Re: t5/longtubes
BigDave, do I see a Spohn tranny xmember there? Looks like on the pass side you actually routed over the xmember with 1 tube rather than under like the driver side. What size is that tube?
Old Jul 27, 2007 | 07:41 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Re: t5/longtubes
the hookers definately save you a headache in that part. but the hookers also typically require grinding on the k member for extra clearance, they did in mine and ive seen quite a few others on here.
Old Jul 29, 2007 | 09:31 PM
Car: 87 iroc
Engine: 410 sbc
Re: t5/longtubes
ac- it's 2.5 back to single 3.
