Got Long Tubes, Now What?
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Picked me up a new set of Hedman LT's at the swap meet for $70. Now I need to decide what to do from the headers back. I'm thinking Xtensions into 2-1/2"bullet mufflers, then like a foot of 2-1/2" piping as tailpipes. Or I could do an X-pipe, or custom make it into a single exhaust. Need sumthin that will make my LB9 sound kinda mean.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you can/want to go dual, then do it. No real power gains but it'll sound pretty good PLUS it'll support a future motor making alot more power. Duals may also be cheaper than buying all the parts to make it into a single - depending on what you want.
dual bullets would be the easiest, but Im not sure how it will sound dual, with LT's, on a 305. I had a single bullet on my 305TBI Camaro with a cutout right behind, and it sounded bad down low, but good when I got on it. The bullet I had on my LT1 Z had the cutout farther back and it sounded real good.
Id like to try the Flowmaster Delta Force race mufflers, but they're a lot more expensive.
Car: '72 Chevy Nova
Transmission: TH350
You could go with the 40s series single chambers, they aren't all THAT expensive.
I have one on the car now, mounted where the cat goes, and with an 18" tailpipe. It sounds real good and deep. But its too low to the ground, and trying to mount 2 of them higher up might not be possible.
Right now I just wanna know what might sound good from other peoples experience. Then I can compare prices and practicality.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
are you sure? check out the flowmaster single chamber mufflers FLO-325108, they are made for ground clearance and are a race muffler, here is the link:
Flowmaster Delta Force One Chamber Race Mufflers: FLO-325108 - summitracing.com
i am goin hedman 68460 long tubes as well, along with s-bends, summit h-pipe SUM-642025, 2 of these mufflers, and turn downs before the axle....
my bad, I have the 40 series 2 chamber muffler. The Delta Force 1 Chamber mufflers I am considering. If I find one or both on eBay Ill buy them.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I had those headers. Then went into some s-bends from Hedman
Then it was straight 2.5" pipe into a pair of Dynomax bullets. The car was really loud, but it was a cheap, easy exhaust system that flowed really well IMO. Not to mention ground clearence was still good.
