headers question
Old Nov 12, 2006 | 09:34 AM
3vi1p3nguin's Avatar
Car: 85 Iroc-Z
Engine: 350 4bbl
headers question
ok, so I drive an 85 Iroc, but most companies have headers listed for the 86 and up irocs, but forget about the 85. i want to do my exhaust from the headers back and was wondering if i got the 86 headers, and the exhaust for that if it would bolt up, or is it for clearence purposes?
Old Nov 12, 2006 | 11:41 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
i have the flowtech you can get from advanced, but they dont have emissions on them. so if you can get rid of the emissions on your car get those,and they come with a y pipe you have too get welded.
and yes they should work,or call and talk too the company and they should help you out,or any parts store can help you
Old Nov 12, 2006 | 06:37 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving to exhaust board.
Old Nov 12, 2006 | 08:31 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Hey 3vi1p3nguin, I think we are from the same place in Michigan.
Find headers with a y pipe, it's the easiest way to go and still have ground clearance.
Old Nov 12, 2006 | 10:36 PM
Car: 85 Iroc-Z
Engine: 350 4bbl
wow, up in the UP? thats the middle of nowhere, im actually south of ann arbor, so im not that far out.
but either way, im looking at edelbrock headers, and they come with a y pipe, its just the year listing that i wasnt sure about, like if they had a different size collector or something like that
Old Nov 13, 2006 | 05:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following will fit your requirements: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR). Direct fit 3-inch mandrel-bent system from the collectors back (no fabing, no welding). Recommended.
JamesC
Old Nov 16, 2006 | 07:13 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
James C, does Hooker make the 2055's without the A.I.R. system tubes. Also, does the y-pipe that comes with the headers bolt directly to the stock large oval opening square 4-bolt flange? Thanks, Badman
Old Nov 16, 2006 | 08:49 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Http://www.jet-hot.com also offers various model / year, different brands and some in house configurations at reasonable prices.
Old Nov 16, 2006 | 08:58 AM
JamesC's Avatar
As far as I know, the 2055's are emission's compliant. I had the air tubes cut and welded closed. The Y has no provisions to bolt to the four-bolt cat (the Y is round, the cat oval, IIRC), which is why I chose the system I mention above.
JamesC
Old Nov 16, 2006 | 02:56 PM
Wadebryant's Avatar
Instead of cutting the emmisions tubes on the headers and welding them, I ordered mine without. If you go that route, make sure you ask for headers with an 02 bung otherwise you'll have to add it.
Old Nov 16, 2006 | 03:14 PM
JamesC's Avatar
I'll be darned. I didn't realize they existed. Cool.
JamesC
Old Nov 17, 2006 | 03:13 AM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
The only headers I know of that will bolt directly to the 4 bolt cat is the edelbrock TES # EDL-68733 at summit. I would rather go with the Hooker 2055's and convert the whole car to a slip fit 86+ cat and cat back.
Old Nov 17, 2006 | 05:09 AM
JamesC's Avatar
Wade, where did you order from?
JamesC
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
