Shortys or long tube?
Old Mar 7, 2007 | 07:47 PM
rebel1222's Avatar
Car: Looking
I just installed a 350 in my 88 camaro. I would like to get some opinions on what the difference is between shorty headers and the standad long tube variety. And, whcih kind you would install given a choice.
I want to install the ones that are the easiest to install and that will give me the fewest problems.
thanks for any comments,
Kevin
Old Mar 7, 2007 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If ease of installation is a concern at all you'd probably want to stick with shortys.
Old Mar 7, 2007 | 09:37 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
shorties
even tho u may get more performance out of longtubes ur building a small block street car no point going threw tons of hassle for a few more ponies go with a nice set of hedman shortie w/ it's y-pipe
Old Mar 7, 2007 | 10:19 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Long tubes are best left to older muscle cars and garge queens, they reduce ground clearance and increase install woes. For flat out performance, LT's can't be beat... but it's not worth the hassle on the street.
Old Mar 8, 2007 | 10:29 AM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
I dont know what you mean by hard time to install i installed mine in about 2 hours and thats with taking off my shortys and y-pipe if it was me i would go LT's i think it is much worth it sounds better and runs alot better i will never go back to shortys just my 2 cents Later Daniel
Old Mar 9, 2007 | 12:34 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Shorties.
Old Mar 9, 2007 | 03:46 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i have long tubes.
get shorties.
Old Mar 10, 2007 | 12:33 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Are LT's legal in CA?
Old Mar 10, 2007 | 12:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No
Old Mar 10, 2007 | 01:22 AM
Grim'91Z's Avatar
Engine: L98 5.7L V8
Didn't think so.
Old Mar 10, 2007 | 09:48 AM
Car: 90 Camaro RS
Engine: 305 TBI
even if LT's were legal, I'd still get shorties.
the header collectors are VERY close to the ground on Long Tubes...@ stock ride height.
Old Mar 10, 2007 | 06:58 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
I'm gonna settle with shorties myself. If longtubes drop as low as everyone says, then I wouldn't want to put them on anything except a 4X4.
Old Mar 10, 2007 | 08:35 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Get shorties. Just make sure the y pipe is modified large enough to go to a decent (at least 3") cat back system. Hooker had the two headers going into a 2-1/2" pipe. My muffler guy modified the ypipe to 3", installed a new pipe that deleted the cat, and welded all the joints that I put together for $300. Enjoy your new system!
Old Mar 10, 2007 | 09:36 PM
Dans87GTA's Avatar
Im going to have to get some pics of my LT's they dont hang down far at all and my car is stock ride height. ill try and get some in the next few days.
Later Daniel
Old Mar 11, 2007 | 01:26 AM
Car: 90 Camaro RS
Engine: 305 TBI
In the meantime, here are 2 pictures of the horrible clearance issues created by installing Hooker 2210 1 3/4 primary long tube headers. click to enlarge
Old Mar 15, 2007 | 10:19 AM
DarkRS91's Avatar
Car: 1991 Camaro RS
Transmission: 5 speed
Axle/Gears: 3.08
Go with the Shorties. I went with the Hooker 2055 set with the Y-Pipe. Nice setup, cant complain
Old Mar 15, 2007 | 10:43 AM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
I have long tubes and i have a big problem with ground clearance
Old Mar 15, 2007 | 11:47 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
well, i guess i'll have to jump on the bandwagon and say shorties.. hooker long tubes give absolutely horrible ground clearance.. you have to have a custom exhaust or ypipe made.. but for power, LTs.. for less hassle and power just short of LT's, get the shorties..
EDIT: if my sig picture was more clear, bigger and didnt have the text over it, you could see the LT's on my car..
Old Mar 18, 2007 | 09:56 PM
jords3rdgen's Avatar
I put shorty's on my 86 V8 coupe i got little sound and power not what i was expecting. Go with long tubes i wish i Had.
Old Mar 19, 2007 | 12:25 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
depends on what tranny you have... Its a pain in the butt to find LT's to fit my T-5. I know super comps fit.. but they have horrible ground clearance. I bought a set of hedmans cuz they looked alright, turns out i will have to cut them up and do a litttle welding to make them fit. Not gonna happen. I'm going to buy shorties instead.
Old Mar 19, 2007 | 04:12 AM
rebel1222's Avatar
Car: Looking
Shorties are the better option. Especially for every day drivers. Their a much better fit. And, unless your trying to push 300hp, on a car you can't afford to drive everyday(Gas), then Lt's won't really benefit you that much more, compared to the low ground clearance, and the PITA to install.
kevin
Old Mar 19, 2007 | 04:21 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i ran longtubes for 2 yrs now and even with my car llowered i dont have any ground clearance issues.i run heddman longtubes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
