will monte carlo 305 headers fit a 305 tpi camaro?
Old Apr 18, 2007 | 02:58 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
What the title states..i have a line on nearly new ceramic coated header that came off of an 80s 305 monte carlo..they are shorty headers. What do you guys think? any chance of them fitting?
Old Apr 18, 2007 | 03:15 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: will monte carlo 305 headers fit a 305 tpi camaro?
I would assume that you could get them to fit. The only thing I'd be concerned about is the flange angle lining up where it connects to the Y-pipe.
Old Apr 18, 2007 | 03:20 PM
subroc's Avatar
Engine: 355 TPI
Yea i was thinking that too. Worst comes to worst i could get someone to make a Y pipe for me. Im probably looking a these headers for about 50 bucks so i was really curious.
Old Apr 18, 2007 | 03:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
There is no way a Chevelle (aka Monte Carlo) header will fit a Camaro.
Completely different body and Chevelle has a frame so the tubes go up to clear the a-arm on the right side, no room for that on an f-body.
Old Apr 18, 2007 | 04:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
...where did a Chevelle ever come into this? It seems like the Edelbrock TES shorty headers themselves were the same for F and G bodies. I highly doubt the Y pipe will fit but I think the headers might. I guess if it was me the headers better be free because making a Y pipe is a lot of hassle for shorty headers. Lots of work for a minor return.
Old Apr 18, 2007 | 07:17 PM
subroc's Avatar
Engine: 355 TPI
I was about to ask the very same question. I do realize the monte carlo and the chevelle were basically the same car back in the early 70's (when the introduced the monte carlo in '70 it shared a lot of chevelle parts) but this is in the 80s. So not chevelle.
Old Apr 18, 2007 | 09:28 PM
Originally Posted by Dyno Don
There is no way a Chevelle header will fit a Camaro.
Completely different body and Chevelle has a frame.
Yeah he's talking about an 80's monte, not sure how similar that was to the chevelle though.
I just checked the product number on hooker headers for a camaro and a monte and they are 2460 and 2466 respectively...so something about them is different. Now, it's either the way the primaries are routed (in which case I think either configuration would be suitable), or the way the flanges line up.
It's a gamble man, until someone comes in here who has tried this swap before and can tell you ya or nay
Old Apr 18, 2007 | 11:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Chevelle was the generic name for the a-bodies as well as a model itself back in the day, and it carried over to the g-bodies in the 80's. Monte Carlo, Malibu, Grand Prix, etc, were all g-bodies, but they were also a-bodies when the Chevelle was around.
The driver's side header would fit, but the passenger side header has a different routing and will not fit.
jhawkeye
May 25, 2022 06:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wvcamaro
Sep 4, 2015 08:38 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
